Electronic fuel pumps? pressure? wiring up?
From Bunbury Western Australia
Hi all
I am almost ready to drop in my new A15 but before I do I need to find an electronic fuel pump to feed the twin sidedraught weber carbs with enough fuel. I don't know exactly what type of pump to get or what pressure it needs to pump at so if anyone can suggest a pump that will feed the carbs that would be super! also I am unsure how to wire the pump up so any ideas on that set up would also be great
Posted on: 2005/12/20 6:53
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: Electronic fuel pumps? pressure? wiring up?
From Christchurch. NZ
4 PSI is plenty enough pressure, it should be mounted by the fuel tank, preferably with a restricted return line. it should be wired to the ignition swith through a relay, you can also include an isolating switch if you so wish.
Although the factory mechanical fuel pump delivers plenty enough fuel for a road car on webers.
Posted on: 2005/12/20 7:13
I would use the standard fuel pump but unfortunateley the hole where the pump goes has been converted into an engine mounting point so thats out of the question. I was thinking of just putting a pump after the fuel filter and pumping it straight into the carb with no return line. Would that work? I don't want to redo the entire fuel system just get the engine running on an electric fuel pump
Posted on: 2005/12/20 12:58
Still mount the pump by the tank, put a fuel filter before the pump, and you don't have to run a return, it's just optimal to do so.
Repco do an aftermarket low pressure fuel pump, if you are looking.
Posted on: 2005/12/20 19:31
From sydney australia
check under the back of series 2 bluebirds,they have a large facet fuel pump,with a mounting point for a fuel filter.these come on a huge bracket,which can probably be cut down & fitted under a 1200.worth a look in my opinion.
Posted on: 2005/12/21 7:37
this is the type I used on my ute, I mounted this right beside a fuel tank.
Posted on: 2005/12/21 11:09
ok yep looks like an easy enough installation....does that hose on the left hand side say not for fuel?
Posted on: 2005/12/21 14:01
From Perth
Looks like same pump as mine
I run from tank thru filter.... to the pump..... then to front of car........ thru malpassi reg....... thru another filter..... then into carbs.
No return line
Can't say I've ever had a fuel starvation problem either.
Posted on: 2005/12/21 14:06
From Invercargill, New Zealand
That hose is not suitable for fuel injection but is fine for carbs.
Posted on: 2005/12/21 14:30
