(1) 2 3 »
turbo questions
From Blue Mountains,Syd,Aus
hey guys.im buying a ca for my ute minus the turbo .just wanted to know what turbos people recommend.i dont want to use the stock turbo but i want something the will fit on the stock manifold.any info will be much appreciated
Thanks, Mat
Posted on: 2006/1/22 0:19
Re: turbo questions
From sutho shire
s15 bb turbo on a budget or if u wanna spend little more buy the Gt2530
Posted on: 2006/1/22 1:33
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: turbo questions
So thats fits on the standard ca manifold. i dont know a whole lot about this so any input is good
Posted on: 2006/1/22 4:47
Re: turbo questions
From Bendigo, Victoria, Australia.
yes a 2530 wil lfit on the ca manifold. but highflowed t28 (s15 ball bearing) or a t25 (s13/14 bush bearing) turbos work fine in these light cars.
other good snails are the hks 2535 (0.84 A/R) and 2510 (0.64 A/R)
Posted on: 2006/1/23 0:58
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: turbo questions
From brisbane
You need to be more specific with what you're after mate. What sort of power figures are you chasing? What is your budget? What sort of power delivery do you want?
Anything in the T25 - T28 range will fit as it will have the same flange pattern. There are usually small mods that need to be performed to get each turbo to fit i.e. modifying oil and water lines, rotating housings etc. But essentially any of the turbos from this family will bolt up.
My picks -
$200 - $350 - T25G This was the factory turbo on the S13 SR20DET. They are slightly bigger so you will see a power jump with minimal increase in lag. They are very cheap but also very old so may well need a rebuild.
$500 - $800 - T28 There are several different T28 turbos with the most common being the SR20DET factory models which had either a .64 exhaust housing on the Silvia/200SX or a .86 exhaust housing on the Sunny GTi-R. The GTi-R turbo will give you more power but with more lag.
$900 - $1200 GT28BB These are the brand new ball bearing versions of the 200SX turbo and are available everywhere nowadays. Excellent turbos with a very good power/lag compromise.
$1250 - $1500 GT28RS This is commonly referred to as the Disco Potato. Exceptional turbo but possibly overkill on a CA.
This is just a very quick run down on a few of the available options. There is an absolute smorgasboard of choices available to you. It is also a great time to buy as new turbos have never been cheaper.
Posted on: 2006/1/23 2:01
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: turbo questions
Thanks for that fellas.my main aim for my car to have a reliable cruiser that i can take out at any time and have nothing to worry about.I want a little bit more go but nothing to silly.again thanks for the info, much appreciated.I'll no doubt be on here quite often through the duration of my project.
Thanks, Mat
Posted on: 2006/1/23 8:50
Re: turbo questions
From penrith,sydney,aus
BORING
whos wants reliability
dont worry mat your ca will give you all the reliability you need
Posted on: 2006/1/23 9:00
Re: turbo questions
It hope so shaun,it will be reliable.speaking of reliability, your pp rotary will be oozing with reliability wont it...
Posted on: 2006/1/23 9:04
Re: turbo questions
thats bp mate,bp
Posted on: 2006/1/23 9:06
Re: turbo questions
shaun wrote:
thats bp mate,bp
Sounds like bs mate,bs
Posted on: 2006/1/23 9:08
(1) 2 3 »
