First congadulations on never having a warped carbie! ( I would like to see it! even smaller than 1 mm is a lot of warpage on a carbie!)
Regarding cork gasket- I have never seen them used ( maybee they will last but probably they won't! )
Personally i wouldn't bother putting the carbie back together with standard gaskets, as even you said it - 10 psi only for the first month!
Trust me if you drive a boosted car you wont be able to stop yourself increasing the boost, even if you have strong will power!
Regarding diesel turbos - From what I know diesels and petrol engines have a big differents in exhaust gas flow! So unless you know turbos I would stick to petrol turbos for petrol cars!
Vacuum secondaries - Being yours is an 80 model chances are it has vacuum secondaries! ( not sure! )
If you have a vacuum line running to a solenoid to open the secondary throtle valve ( you have vaccum secondaries!)
If you have mechanical linkages to the secondary throtle valve! ( you have mechanical secondaries! )
( I dont know how else to explain them! )
Mechanical secondaries are required as if you apply boost to vacuum secondaries they will not open up and this will cause the engine to lean out!
Regarding the Turbo - I said a T3 off of a Nissan VG20 engine ( not sure which car this came in! )
This T3 has to wastegates! One works as normal and the other is an anti-lag wastegate! It works by causeing the exhaust gases ( at low boost ) to travel in a narrower path! this making higher velocity causing the turbine to spool up better at low RPM! then is opens up at a certain boost pressure to slow the turbo down at a higher RPM This making the car keep the same boost level!
( On the 1200's we left off this anti-lag wastegate so that the turbo would spool up more and increase boost!)
This is basically the same as modifiying a turbo to have a large compressor wheel and a smaller turbine wheel!
If you get a turbo off a bigger engine it means you will have to rev the car more to get enough gas flow from the exhaust to spool up the turbo! But at the same time this will mean the car will have a higher top end power as the Turbine housing will not be causing as much back prssure!
Regarding Radiator Intercooler- Like the other blokes have said the radiator is not designed to flow like an intercooler! ( it is designed to cool water and to cool it it would be better if the coolant was slowed down! This telling me that it couldnt flow air as good as an intercooler!)
Just look at the drag cars if a radiator was a good intercooler I am sure all these cars would use them!
