(1) 2 3 4 5 »
a15 turbo now running
From campbelltown (sydney) australia
hey guiys just thought id let everyone know i have my dellorto turbo a15 running, its not a great tune but runs well, just doesnt want to idle and tries to stall. although, once on boost it goes very well. just a few problems need to fix, it has a vacuum leak or something as the boost gauge fluters up and down heaps quick and doesnt smooth out. need to seal up a slight leak in the carbies, just leaks tiny bit of fuel. and i need to figure out my water injection and get the air filter sorted out so it doesnt hit the radiator.
another thing before i go tighten my head and tune my tappets, wat oil pressure shoulkd an a15 make at idle warm, mine sits on 25 at a high idle maybe 1100rpm, but if u go much lower the oil pressure drops to about 12 psi really worries me.
Posted on: 2006/1/23 10:40
* caution, sunglasses must be worn to view my ca18det *
Re: a15 turbo now running
oil pressure should be no less than approx 20psi ive been talking to people about when hot, similar problem to what mine had.
i idleed it at 950rpm pn the webber and runs ok with 25psi at idle. Also looked into the oil pump spring...could be worn but if your engine is rebuilt should be ok if replaced.
Posted on: 2006/1/23 10:46
spring in the oil pump wasnt replaced, im going to tighten the tappets , maybe it will run smoother and might be able to get a good idle and bit of oil psi, hehe working on dattos at night in summer is great, day time today whooaaa way too hot.
Posted on: 2006/1/23 10:50
From Melbourne, Australia
very cool!!!
whatever you do dont run it without the air filter, cause it will kill your turbo inlet impellar
been there done that
Posted on: 2006/1/23 10:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch. NZ
That's excellent Kegs, so you decided to stick to the Dellortos then?
Posted on: 2006/1/23 11:08
From Sydney Australia
Well done its been a long journey.... i bet it will kick ass once its fully tuned.
good luck
Posted on: 2006/1/24 7:16
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
any more news????
keep us updated, very interested in how it goes
Posted on: 2006/1/24 9:48
1200 Coupe Rallycar
From Ipswich,QLD
Great to hear kegs hope its all good...
Posted on: 2006/1/24 9:52
thanks guys, really encouraging to hear positive things. i had a mate play with my tune today and has got it running a bit better, we are going to take the airbox off and get perfect throttle synch and idle speed and that then put the box back on and see what happens. its only my idle that is bad, as soon as its boosting it sounds like a jet and runs so smooth.
its just all annoying little things now, hopefully will have more news tomorrow night.
Posted on: 2006/1/24 10:19
From penrith,sydney,aus
hey kegs glad its all running
should really fly once all the bugs are sorted i know my old a series used to bring a smile to my face every single time she come on boost
Posted on: 2006/1/24 10:29
2 door 1200 sedan project l20b stroker
(1) 2 3 4 5 »
