« 1 (2)
Re: help needed with wheels
From Alabama, U.S.A.
The pulsar (EXA) wheels will bolt on cause I bolted a set of factory pulsar wheels on my 79 210 (sunny) no probs. & they were 13's too
Posted on: 2006/1/24 3:42
wernt the exa ones alloys? hes looking for palin steel rims for hubcaps.
Posted on: 2006/1/24 3:45
I stand corrected about FWD cars. Leave it to Nissan to make newer parts fit our older cars!
Posted on: 2006/1/24 3:47
ahhhhhh I see. I have took some of my old steel nissan wheels and cut the centers out and found some wheels off a domestic car here in the U.S. & set me up a jig & welded the centers into the deeper rings before ,maybe you can find sombody to do this for you.
Posted on: 2006/1/24 3:48
thanks for the help so far guys ......
looks like a 5.5" rim in 13" wheel is near impossible as factory ..... excels and the likes are all 5".
there is a company i know of, and have spoken to, that will re-do offsets by removing the centre and rewelding it in the existing rim or into a new wider rim, but cost wise it's not really worth it unless you're going for something really specific in width.
$55.00 to reset offset in orig rim
$75.00 to weld existing centre into new rim at desired offset
do the later with 4 wheels and the cost of buying them and you're pushing up over $300 for a set of steel rims .... not real value for money in my eyes with a 13" wheel just so as to run hubcaps ??
think i'm going to settle with a set of 13x5" stock steelies and sort something else from there.
thanks tho, for all the input so far
Posted on: 2006/1/24 5:46
From Sydney Australia
my mate used hyundi (cant spell it but u know what i mean) elantra steel wheels to make front runners in a similar way to what boofhead was talkin about.......but i cant remember the sizes but its definetly worth checking out......good luck
Posted on: 2006/1/24 6:30
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
elantras are 14inch... and 15 if you get the abss brake upgrade.. thanks for the input though
Posted on: 2006/1/24 10:01
From Adelaide, Australia
Because my partners car has the stanza front end we used suzuki steelies they are 13x4.5 they are near on perfect didnt have to roll gaurds at all.
Posted on: 2006/1/24 10:16
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Newscastle, Australia
pretty sure SAAB's had a 114.3 PCD as well. I use a 15" SAAB spacesaver wheel over my front brakes to get the car into the trailer.
Posted on: 2006/1/24 11:26
Dont die wondering.....
« 1 (2)
