ute tray?
From sydney,Australia
hey guys i am not sure what to do with my ute tray i was thinkin of cuttin it out and replacing it with a new sheet of metal but the sheets of metal arent big enough to cover the whole of the tray floor i was wondering if i should use something else like wood or if anyone in the shire knows of a place where they can fabricate a new floor that would be great.
Posted on: 2006/2/6 7:18
Re: ute tray?
From sutho shire
u can buy sheets of stainless steel and cheqer plate in 3x1.2m which is more then enought to do a tray of a 1200 ute just ring around i know for sure there are a few factory's in taren point that sell sheet metal ect
Posted on: 2006/2/6 8:11
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: ute tray?
From Brisbane
Yer i looked for sheet metal to redo my tray. Couldn't find sheets big enough. But now i am goin to do it with checker plate and it will look real nice
Posted on: 2006/2/6 11:25
Re: ute tray?
does the sheet of checker plate fit the size of the tray? do they come bigger than the sheets of just standard sheet metal?
Posted on: 2006/2/7 7:41
Re: ute tray?
From sutho shire
i have seen sheets big enough 2 fit it the tray in a standard size in cheqer plate and sheet metal best bet is 2 ring around from yellow pages and ask a few local metal shops good luk
Posted on: 2006/2/7 10:14
Team New skool
Re: ute tray?
From Blue Mountains,Syd,Aus
just a question.wouldn't a sheet of cheqer plate that big be pretty heavy.
Posted on: 2006/2/8 8:28
Re: ute tray?
From sutho shire
depends on thickness of the cheqer plate would be heaps havyier if u went straight over existing floor i would cut old floor out b4 installing unless u have 300rwhp and need the weight
Posted on: 2006/2/8 8:39
Team New skool
Re: ute tray?
doesnt sound like a bad idea for u mate you haven't got much more to go.
Posted on: 2006/2/8 9:11
Re: ute tray?
From Melbourne, VIC
If you buy checkerplate 1.9 mm thick the extra weight is hardly noticeable. Probably only 10 odd kg's heavier. Holds the rear end down nicely.
Posted on: 2006/2/8 9:45
Speed costs money. How fast do you want to go?
Re: ute tray?
From Melbourne AUS
i replaced the floor of my first project ute...
i remember i couldnt find sheets big enough to do it all in one piece.. so i had a join going across the car between the wheel tubs on the middle chassis rail... i removed the old flooring first (a time consuming job) then welded in the new one....
came up alright for a backyard repair
Posted on: 2006/2/8 11:26
1973 B110 A12
