(1) 2 3 »
CA18DET
From Melbourne, Australia
chech this site, Ca18DET with wiring and computer and that, (no gearbox) only $1600
you dont use the gearbox anyway so this is damn cheap!
The mob is Adelaide
Cheap CA18DETs
also a good site to check out diffrent power outs of motors
Posted on: 2002/11/7 8:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18DET
From Adelaide, Australia
does an a12 gearbox bolt on to a ca18
Posted on: 2002/11/7 8:24
Re: CA18DET
Posted on: 2002/11/7 8:29
Re: CA18DET
Look what we have here! another post seeker!
( Oops looks like I just racked up another one! sorry!)
Posted on: 2002/11/7 8:36
Re: CA18DET
From Tassie, Australia
No an A12 box does not, some one here will soon tell you what does bolt onto the back of a CA18 motor. I think there are a few types that will fit.
Posted on: 2002/11/7 8:37
Re: CA18DET
yeah thought so some one told me today that it would and i abused them about it and im just backing my self up
Posted on: 2002/11/7 9:04
Re: CA18DET
From LISBOA, PORTUGAL
Michael
Sorry for my ignorance. Why can't you use the CA18DET gearbox? Can't you modify the tailshaft so it can fit in?
Thanks
Ricardo
Posted on: 2002/11/7 10:32
Re: CA18DET
From Sydney, Australia
Ok here goes.
For a CA18DE/DET- Series 3 Bluebird Bellhousing. 2.4L Skyline Stumpy 5 speed.
There's also 2 kinds of Gearbox, Silvia and Gazelle. The Gazelle ones are about $400-$500, but they are about the same length as the stumpy combination, that's why they are so expensive. They are stronger and newer than the 2.4L Skyline. The two CA18DET boxes have similar internals which are strong enough to withstand a worked CA18DET. The internals are very similar to the one used on the SR20DET.
I've got a 4 dr sedan, and I'm using the original CA18DET longer box, as I plan to break some while racing. And at $120 each in good condition, makes for a good "weakest link" in the powertrain.
Chris
Posted on: 2002/11/7 11:29
Re: CA18DET
when you say gazelle is that ca20 gayzelle
Posted on: 2002/11/7 11:46
Re: CA18DET
I think you'll find it's a CA18DET import only Gazelles. But I'm not real sure on that. But I'm fairly certain they are Gazelle. They externally look similar to the regular Silvia CA18DET gearbox, but are about 25cm shorter. I assure you they exist, and are more common than A-series 5 speeds. I saw 3 or 4 of them at SSS Automotives when I got my gearbox.
Chris
Posted on: 2002/11/7 12:46
(1) 2 3 »
