(1) 2 3 »
Reset springs vs Blocks
From Sydney
what are the advantages of paying the extra $150-$200 to get your leafs reset as opposed to lowering blocks
Posted on: 2004/6/10 9:49
Street Tail Dancers
1200 coupe - A14
Re: Reset springs vs Blocks
From Mandurah, Western Australia
How low do you want to go?
Personally I would not use anything more than a 1.5 inch lowering block.
I have got a 1.5 inch lowering block and the springs reset 2" lower as well. If I get a defect notive I only have to remove the blocks to achieve legal ride height.
Jarrad
Posted on: 2004/6/10 10:24
From Sydney
i worked out it needs to go about 12cm's lower however much that is in inches. thats a pretty good idea tho i think i might do the same
Posted on: 2004/6/10 13:05
Street Tail Dancers
1200 coupe - A14
12cms = 120mm which is close enough to 4-3/4 inches [4.8" actually]
Posted on: 2004/6/10 13:10
Love your Datsun.
Treat it well.
From Sydney
4 3/4 " sounds like an aweful lot haha
Posted on: 2004/6/10 13:40
Street Tail Dancers
1200 coupe - A14
From Brisbane, Australia
that's because it is an awful lot!
if you want to go that low, it really doesn't matter how you do it - the result will be a shocking ride, terrible handling, and illegal. if that's what you're after, go for it.
Posted on: 2004/6/10 22:52
From Brisbane
where can you get a lowering block? and how much?
Posted on: 2004/6/10 23:34
From Auckland, New Zealand
It's easier enough to just buy some boxing and cap the ends (if you know how to weld).
The most expensive part is getting extended U-bolts made up (high tension steel and threading etc.)
Once you've done all that, your away.
Posted on: 2004/6/10 23:54
#Datopower#
From Brisbane
I think the easiest and safe is just buy lowered springs
Posted on: 2004/6/11 0:08
From Sydney
definitely springs
Posted on: 2004/6/11 3:38
(1) 2 3 »
