1200 ute 1/4 mile
Quite a regular
raced my standard 1200 ute last nite and ran a 21.67. i dumped the cluch at 6000rpm and changed at 5500rpm. she doesnt sound so good any more
Posted on: 2005/7/10 10:40
Re: 1200 ute 1/4 mile
The April 1971 edition of Wheels magazine carried a road test of the Datsun 1200 sedan manual sedan. The average of all 1/4 mile runs was 21.55 sec's with a best time of 21.5 seconds, & this was in a 690Kg car driven by a bunch of old farts.
They didn't break it either.
Posted on: 2005/7/10 11:43
Love your Datsun.
Treat it well.
From Brisbane, Narangba
I thought I read somewhere in the tech section where it said a stocka ran a 19.6 1/4mile. I have never driven a a12 powered 1200 so I wouldnt know. I have been in them and by no means did the feal fast but...........
Posted on: 2005/7/10 11:49
From Mudgee NSW Australia
Take the aircleaner off I recon you will get 20 flat I used to take mine off when i run the stocker A12 dont know if it went any better but it sure sounded more thoaty
Posted on: 2005/7/10 14:03
If In doubt run more BOOST
From Adelaide, South Australia
Back the rpm down to 3000 and you should get off the line better and also shift HARD!!!!!
Posted on: 2005/7/10 15:15
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Brisbane, Australia
Back in the early days as a really poor uni student, I found that a good portmatch could pick up almost a second on a stock A12 depending on how bad it was to start with. . . And then you can remove the choke. . . and then set the stock carb up as a mechanical secondary. . . and then a head de-dagging, I wouldn't call it a port job. . . Take the aircleaner off. . . Wind a bit of advance into the timing. . . cooler thermostat. . . Cut the "hot box" off the exhaust manifold and plated over. . .Then you can stop the alternator charging. . . Low profile tires to lower the final drive ratio. . . The 'er aerodynamic aids could be amusing. Remove mirrors, windscreen wipers. . .
A heap of low $ mods, some of them even worked!
The motorvation? I had lashed out on a 2nd hand G-tech!
Posted on: 2005/7/11 3:41
Did you also polish your car before you did a run ?
Posted on: 2005/7/12 18:24
Albert Einstein
I had to fill this space because I stuffed up.
Posted on: 2005/7/12 18:26
Albert Einstein
From Launceston,Tasmania,Aus
I did some runs back in march in my ute, stock a12,4 speed with all bits still attached.
15 inch wheels with 195/50's...
1: 20.490 @99.00 kph, reac: 0.772, sixty: 2.705
2: 20.859 @100.57 kph, reac: 1.194, sixty: 2.796
3: 21.022 @98.79 kph, reac: 1.050, sixty: 2.794
I did a fourth run but lost the time slip.....As you can see I was in no hurry to leave the line and I didn't rev it out much past 5000 rpm's.
The purpose of the exercise was to get some "on board" vision for the dragways new advert...
Posted on: 2005/7/15 8:22
Proud member of " The Tasmanian Datsun Owners Group"......
