What A series bellhousing do i need to fit Stanza 5 speed guts in to
From Adelaide, Australia
ive heard that u can fit L16 stanza 5 speed guts into u sunny wagon 4 speed bellhousing. is this true? what has to be done for this 2 work?
Posted on: 2005/7/23 15:30
Re: What A series bellhousing do i need to fit Stanza 5 speed guts in to
From Newscastle, Australia
nope cant be done you need a 63a box which suits an a series
Posted on: 2005/7/23 20:07
Dont die wondering.....
From Victoria
You could use a 1200 auto bell housing and then make a adapter plate to go between them.
Posted on: 2005/7/23 22:17
surley there must be another way. i need a box that can easily handle 160hp in a 1000 ute
Posted on: 2005/7/24 5:31
Just use a 63a transmission for an A14 (from a B210) It can handle 160hp.
Posted on: 2005/7/24 6:00
From Central Vic
dellow engineering make a celica 5 speed conversion
this is what i use
a standard sunny 4 speed will take 160hp if you not ham fisted and run very good oil etc
Posted on: 2005/7/24 9:39
From ipswich
is there such thing as a gx 4 speed gearbox coz my gear box has gx written on it as if it came out of a car at the wreakers, like a 1200 gx, but i doubt there is any difference to a standard 4 speed
Posted on: 2005/7/25 1:03
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Yes, all Datsun 1200 GX models had a four-speed. They are the same strength as the standard transmission. The gear ratios are different from the regular models if I recall correctly; there are at least three different gear ratio sets for 1200 transmissions. See the chart of 4-speed ratios at the end of 5-speed Overview
Posted on: 2005/7/25 2:29
From ipswich
alrite so is the gx 4 speed beter than a standard 4 speed
Posted on: 2005/7/28 0:39
datsun 1200 ute
