Why???
From Bridgetown, Barbados. W.I
why are the Lseries engines mounted leaned to one side???
can they be installed uprite??
Posted on: 2005/11/16 10:51
Life's better SIDEWAYS!!
Re: Why???
From Sydney, Australia
brake clearance? And the sump is still flat to the ground across the sump gasket..
Look at the sump and gearbox selection before going that way.
Chris
Posted on: 2005/11/16 13:57
Re: Why???
From Brisbane, Australia
3 things I would investigate:
1: Oil return
2: will the bonnet close
3: will the gearstick dig into your thigh
I don't know for sure but keep an eye on number 1, number 3 can be introduced to an oxy.
Posted on: 2005/11/16 21:57
Re: Why???
1: Oil return
oil return cannt be a problem cause the Lseries blocks r used when doing Ka24e conversion, with the engine standing uprite.
I have a flat oil pan already thats why im asking the question.Modified for a 1200
Posted on: 2005/11/17 0:02
Re: Why???
Oil return from the head. . .
You don't want the oil level above your valve stem seals!
But if you keep it sideways you should be able to keep it draining away.
Posted on: 2005/11/17 3:40
Re: Why???
From California
that doesn't mean it's the right thing to do. also not sure what u mean by ka24e lseries block conversion.
Posted on: 2005/11/17 3:52
Re: Why???
From Arlington, TX, USA
To stand it upright you need a Z20E or Z22E oil pan. Bolts straight on and is set up for an upright engine.
Also, you'll have to address the intake manifold somehow as your air/fuel will now be running uphill. Doesn't matter with EFI, but with carbs it will.
Posted on: 2005/11/17 5:48
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Re: Why???
If stock, yes. but you can use the Z20E/Z22E transmission, or heat and bend the shifter over.
Posted on: 2005/11/17 5:52
Re: Why???
thanks guys next thing is to see if it fits under the bonnettt now
Posted on: 2005/11/17 10:59
