Dasant wrote:
Not sure what you mean about the gaskets and axles lining up, i was hoping to just bolt in the entire diff with axles, drums etc to the tailshaft. The sunny it came from has coil sprung rear end where as the 1200 has leaf.....
Ohhhhh, you say 'diff' but you dont mean the diff at all, you mean the whole rear axle assembly, which is something different entirely.
The 'diff' is the bit in the middle.
The H150 diff [differential] from a Sunny [B310] will bolt into a 1200's H145 rear axle housing, but the centerline of the side gears is 2.5mm further back from the gasket face.
Some people just bolt it in anyway & go, but others will use a 2mm thick spacer ring with a second gasket, which is .5mm thick. [one on either side of the ring] The combined thickness of the spacer ring & the second gasket will push the diff forward in the rear axle housing by the right amount, or so the theory goes.
This would overcome all the problems associated with making suspension mountings, then making the handbrake work, & also avoid those irritating problems with excessive axle width.
The 1200 driveshaft will not bolt to the new pinion flange, but the Sunny driveshaft stands a good chance of being the right length, so compare, & use it if it will fit.
