45 weber sidedraft on A12
Quite a regular
Just wanted to know if you guys think a 45 side draft would work on an A12 with the machanical fuel pump delivering the fuel? Or should I just get a same facet pump to be safe? The carbi was on the front of my turboed A14 but it may as well be used on the ute I have instead of just sitting around on the bench!
Posted on: 2007/3/28 16:59
Re: 45 weber sidedraft on A12
Quite a regular
Hard to believe no-one on here has an answer to this?
Posted on: 2007/3/29 23:23
From South Africa, Bloemfontein
There is a couple of people on this site that run the standard mechanical fuel pump on two 40 sidedraft webers.
I think it will work with a single 45 sidedraft.
Put it on and see what it does.
Posted on: 2007/3/29 23:49
1977 Datsun 1200GX
single 45 will work and the standard mech fuel pump wont have a problem .... you having any luck with selling the sedan ?? i here ange could be easy to convince
Posted on: 2007/3/30 0:33
From penrith,sydney,aus
i have the standard fuel pump feeding my twin 45mm on my a14 and its fine
Posted on: 2007/3/31 16:10
2 door 1200 sedan project l20b stroker
