When you only have a few heat settings to pick from, go the hotter setting and pull the nozzle back an inch (experiment), this will increase resistance and reduce temp.
Make sure everything is clean before starting, don't make life hard for yourself.
When welding real light stuff or pinholes, whack a piece of copper behind it. This will pull a fair bit of heat out and support the molten metal without sticking. I use a flattened piece of water pipe.
It will get hot quickly so wear gloves. . .
I have since purchased a Uni-mig procraft 240 and haven't looked back. About $1300, depends on how often you intend to use it.
Might work out cheaper to get a professional in if there is only a little work to be done.
Uni Mig .pdf of specsFor sheet this is HUGE overkill. I am not saying that this is the best welder around, infact the paint quality is siht, falling off in places due to surface rust below, ie bad prep. But it has been working for me for the last few years. Only home use.
