FS: ca18detman's old 1200 coupe CA18DET
From Brisbane, Australia
has been fully engineered in NSW (Engineer reports supplied) CAN BE REGISTERED!
weld in CDW steel cage to current CAMS specs
IPRA legal flares and front/rear spoilers
body in VGC - no rust. you won't find a cleaner Datsun 1200 shell.
CA18DET 190rwkws@15psi-230rwkws@22psi
tuned on 98RON pump gas
Venolia pistons +.020" 8:1CR
Total Seal rings
Argo rods
Nitrided crank
Tomei procams 260deg 8.8mm
Tomei valve springs
Tomei vernier cam gears
Ported head
ARP stud kit
MLS steel headgasket
HKS GTRS turbo
braided oil and water lines
tuned length thick wall steam pipe turbo manifold
sonic studs, metal-lock interference nuts
genuine Nissan MLS flange gasket
SARD 700cc injectors
SARD FPR
Carter black 110gph low pressure lift pump
1lt surge tank
Bocshe motorsport 044 700hp efi pump 3/8 feed with 5/8 return.
PWR Intercooler, silicon turbo piping
PWR alloy radiator
PWR oil cooler
12" Spal fan
Autronic SMC engine management
Autronic 500R CDI 4 channel ignition
chromemoly flywheel
Custom daiken extreme 4 button sprung centre clutch
S13 Silvia 5spd
4.375 H190 diff 29spline 30mm axles
15*7 & 15*8" Superlites
205 & 225/50 Toyo Proxes RA1
Nissan Z32 300ZX 4spots and vented discs front
Mitsubishi Scorpion slotted rear discs & calipers
Koni custom vavled shocks front and rear
height adjustable platforms front
JTS custom reversed eye rear leaf springs
adjustable strut tops
current adjustment:
4deg camber
5deg castor
2mm toe out
46.35 at Mt Cotton
51.54 Grafton Hillclimb
58.23 QR Sprint track
PRICE: $15,000 or VERY near offer.
CONTACT: Harry 0400 656 191
REASON FOR SELLING: don't get time to use it - so have bought a turbo Supra road car instead and the Datto has to go.
tandem axle trailer with load sharing springs, hydraulic over-ride brakes and near new light truck tyres available for additional $1500 with the car if required (will not sell seperately - pls do not ask).
Alternatively, I can deliver the vehicle as far as Sydney for $500.
Posted on: 2008/5/8 2:02
Re: FS: 3J IPRA 1200 coupe race car CA18DET
From gold coast QLD.
Whats really going on Harry?You've just done all that improvement stuff and now your bailing??
Posted on: 2008/5/8 3:18
The main thing is I've had it almost 12 months and only used it 5 times - 3 MtCotton Hillclimbs, 1 Grafton Hillclimb, and one sprint at QR. I haven't used it at all since I bought the Supra late last year. So I think I'd be better off with the money than the car.
And I have too many cars anyway - Patrol, Supra, 1200 coupe, 120Y... The Supra may be going soon too.
Posted on: 2008/5/8 3:47
Yeah,i suppose....the current economy is'nt helping the motor sport cause either,a lot of the guys i know are starting to pull thier heads in anyway,the cost to get anywhere is starting to hurt.
Going to Stanthorpe next weekend will cost me over $140.00 in fuel just to get there and back and thats before i turn a wheel in anger.
Good luck with it mate,it's a top little car and worth every cent to anyone who's fair dinkum
Posted on: 2008/5/8 4:28
From sydney australia
Got a bit suspicious when you started working on the 120Y there Harry. Would love to take this off you're hands, maybe if i win one of those lotto style games. Hope the new owner understands the history of this car, & doesn't just cut it up or run it into the ground.
Posted on: 2008/5/8 4:43
From Newscastle, Australia
good luck with the sale Harry, that car is lethal in the right hands.....and Im a mere mortal too. When I drove it I felt like I got shot out of a cannon. She is one very special car.
It seems like the old guard is falling away mate
These are special motorcars, I would love to have a really nice 1200 road car they are that great. Hard to justify though when you can buy a Twin Turbo or quad cam V8 Soarer for 5k...
Posted on: 2008/5/8 8:12
Dont die wondering.....
From Southern Highlands, NSW, Australia
Good luck with the sale, hope it ends up with someone who will look after it and appreciate the hard work that has been put in. Some of those pics of this car are glorious.
Posted on: 2008/5/8 10:34
'72 1200 sedan hillclimb/supersprint car
updated first post - priced to sell now!
$15,000
will throw in the laptop with all the software and I think it has the old AvGas 1.5bar tune saved on it.
here's some current pics from 11/10/2008 at Lakeside. This was the first time I've driven it since last November and it got called off after 1 run because of too many people crashing. That's why its for sale. I simply don't get the time to use it.
Posted on: 2008/10/20 5:30
From SE Melbourne
...an awesome car - the ultimate goal of mine is to get to where this car is already!
A steal really - I really hope one of the 1200.com gang buy this and keep it in the family (just like when ca18det_man sold it)....unless he wants to buy it back?
Posted on: 2008/10/20 5:43
Mildman, Datsunless
Re: FS: ca18detman's old 1200 coupe CA18DET
if only i had the money mate :( some1 should snap this up quick smart
Posted on: 2008/10/21 6:58
