strut inserts
Quite a regular
From Cairns, Nth Qld
i have 120y front struts and i would like to know what inserts to use being that i am lowering it
cheers
Posted on: 2008/9/20 10:12
Re: strut inserts
From Mandurah, Western Australia
How much lower will the vehicle be when its lowered. Are you thinking of a conventional gas strut replacement or adjustable.
Will you be altering the length of the strut and the spring base to get the vehicle really low??? Or to fit specific rims.
Posted on: 2008/9/20 13:38
Re: strut inserts
Quite a regular
just conventional gas strut and i dont know how much lower the car will sit as i am still waiting of the lowered springs. i have 13x7's going on the car.
Posted on: 2008/9/20 22:35
Re: strut inserts
From Albury
Hi there
For Road use try Nissan pulsar or escort strut inserts.
For heavier duty applications try adjustable konis (Great units but are pricey).When using these in standard struts you need a spacer between the top of the strut insert and the screwing on bit on the top of the strut itself.
Cheers
Bob
Posted on: 2008/9/21 0:13
Re: strut inserts
From Oberon NSW {Bathurst}
All the strut inserts of the Datsun are made to spec. The ajustable Koni will only make te ride stiffer or softer. The height is controled by the spring height and thickness of the wire and the rate of the coil used in the build.
Posted on: 2008/9/21 5:07
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
