1200 sedan drag car
From Rutherford
In need of some ideas of rear end setups for my drag project from ppl that have had experience if this field before.
She is powered by 12A turbo likely to produce a respectable 500 to 600 HP transfering power will be a KEAS 3 speed AUTO with trans brake but unsure of rear end....ive thought about a nine inch would like the strength but not the added weight if i can help it......
any ideas will be helpfull....cheers
Posted on: 2009/2/9 7:34
Re: 1200 sedan drag car
From Melbourne, Oz
In wiki there is a list of diff's and an Idea of the tourqe they can handle
<--- over there!
Edit: diff inches max. torque capacity
H145 5.71 ~100 lb. ft.
H150 5.91 ~125 lb. ft.
H165 6.50 ~225 lb. ft.
H190 7.49 ~285 lb. ft.
R200 7.88 ~300 lb. ft.
Ford 8 8.00 ~325 lb. ft.
Ford 8.88.80 ~500 lb. ft.
Ford 9 9.00 ~600 lb. ft.
Horsepower is irrelevent for the differential. What matters is the torque:
Posted on: 2009/2/9 7:39
"I hav achieved wood"
From Rutherford
is that u ROCSOLID
Posted on: 2009/2/9 7:48
From Melbourne, Oz
Nah?
Posted on: 2009/2/9 7:49
From Rutherford
thanks for the info im thinkin maybe a beefed up r200 diff or along the lines of an r31 diff not sure if they will handle the punishment tho
Posted on: 2009/2/9 7:50
R200? Are you also going IRS?
Posted on: 2009/2/9 8:03
From Rutherford
NO PROBABLY LADDER BAR REAR END IS THE FIRST THOUGHT
Posted on: 2009/2/9 8:27
From Melbourne ( West )
What about a shortened Borg Warner diff?
There is some really quick VL's out there with a heap of tourque
(and they weigh a lot more than the Datto).
They don't 'suck' as much power as a 9inch either.
I have been told by a very good source that the strongest standard holden diff produced was the VS supercharged V6 diff.
Apparently stronger than any V8, N/A V6 or Straight 6 live axle diff.
Posted on: 2009/2/9 9:00
'78 Ute CA18det Project
No matter where you go... There you are
From Geelong, Vic
apparently the hsv BW78s had shot peened centres and stuff...but apart from that they are all the same
Posted on: 2009/2/9 10:01
From Darwin NT
dont forget this is also a rotary so its not going to be a torque monster like a v8 id say find out what the torque figures are then find a diff that can handle about 100ft lb more
Posted on: 2009/2/9 10:09
current project 4x4 patrol...
