(1) 2 3 »
datsun sunny diffs
From Albany, Perth Australia
hey guys just wanting to know what diffs are under your B310 sunny...i have no idea what mine is as its not like my old one, it was an 81 model and had leaf springs on the back but this 80 model i have doesnt....it has coils springs. Just interested to know why
Posted on: 2009/3/14 12:23
1200 Smerf Mobile
Re: datsun sunny diffs
From Perth WA
I thought all B310s had coils?
I know there are a couple of options diff wise.
H145 and a BW maybe?
Posted on: 2009/3/14 12:33
Chris...
i dunno me and jordie where a bit confused as we only new about the springs but mine looks like its original but i dunno....we had a few small problems at the front end with the 15's that i still have to sort out
Posted on: 2009/3/14 12:36
1200 Smerf Mobile
From 6065
both the 666 sunny and yours had the same style of trailing arm coilspring at the rear.all the 310 sedans ive been thru have been the same,maybe the wagons are different? oh yea,b4 i junked the 666 i tried what i always wanted to do, remove the springs and see how it sat on stock rims, it was slammed on the deck and still had full mobility and looked sick! i hope i got a pic...
Posted on: 2009/3/14 13:54
From perth airport
is a 1200 ute diff center an upgrade or wont fit ?
Posted on: 2009/3/14 14:19
perth airport parking
Datsun 1200 ute A14
All the B310 wagons I've seen have coil springs, just like the sedans. They are H150 units.
Late model ute has H165, so the centers won't interchange.
Posted on: 2009/3/14 16:38
K-DOGG did you change the front end at all(the suspension and parts) trying to get the rims on but for some reason the wont.....
what diff wound be on mine as i have no idea which one it is
Posted on: 2009/3/15 3:31
1200 Smerf Mobile
From 6065
no i sold it with the factory super sloppy freeplay front,but the 666's good front end was in the boot and the new owner swapped it,maybe put some spacers on the front if youre havin trouble. those front rims on it now are triumph ones that used to be on desii the blue 1200 from bout 15 years ago, i couldnt find a matching pair for the back. if youre gonna upgrade motor wise i'd look at s13 struts? thatll give you a better rim fitment with the 15s.
Posted on: 2009/3/15 13:46
do you know what diff is in it?
Posted on: 2009/3/15 14:10
1200 Smerf Mobile
From Perth WA
brett does the axle tube stay the same thickness all the way along or does it step down somewhere near the diff the centre? that tells u if its nissan or b/w, the nissan one has the stepdown in thickness.
Posted on: 2009/3/16 1:36
(1) 2 3 »
