(1) 2 3 4 5 »
toyota 4AG 11000rpm???
From Perth WA
anyone know about these? heard the old AE86 corolla some drifters use could come with a 5 valve 4AG that makes peak power at 11000rpm N/A, seems doubtful the ones ive seen drift look like they struggle to break traction.
Posted on: 2010/1/7 5:38
Re: toyota 4AG 11000rpm???
From ACT Aus
umm the 4ag 20v motor makes 163hp but not at those revs, modified possibly? 4ag's can make good power, real good n/a engine
Posted on: 2010/1/7 8:18
unfamilia wrote:
You have bump stops? Your soft
From Perth WA
yes modded, still its F1 high, wondering if its realistic.
Posted on: 2010/1/7 9:15
datsun 1000, Its not the size its how u use it.
From Brisbane
havent you watched initial d? Tak's 86 does that. lol
Posted on: 2010/1/7 9:23
From Melbourne, Oz
F1's do 18ish
Posted on: 2010/1/7 9:33
"I hav achieved wood"
From Geelong
yeah his eight six has got some bullsh*t power eh! i just love the yellow rx7 haha, i just bought the entire box set ;)
Posted on: 2010/1/7 9:36
From Albany, Perth Australia
well yes the 4ag can make that power...i have helped make one...you need the o.s. giken head for starters....which is very costly and need to do some bottom end work, bore and stroke as norm and voila 11k rpm yeeehaaaa
Posted on: 2010/1/7 9:49
1200 Smerf Mobile
i still prefer the 4agze motor...was more fun
Posted on: 2010/1/7 9:55
1200 Smerf Mobile
From Newcastle nsw
4ages are a well sorted bit of gear. They used them in a race class in the u.s. called formula atlantic engines. These where super modified, and from memory spun over 11000rpm!
You can also build gun engines from factory parts because of all the different versions of the 4a. i built one a few years back for a mate of mine which consisted of (from memory) the ae92 block (which has oil squirters to cool the bottoms of the pistons and lube the walls and has as many ribs as the 4agze block), 20v black top crank( light and best balanced ans i think is steel from memory) 20v silver top rods ae92 pistons, and 16v small port head. Gives like 11:1 comp ratio, using factory bits. And after the flogging this one we built cops, i can vouch for them bein bullet proof. revs to 8900 easily, and with some more head and vavle work(which are standard at the moment) and different cams, i reckon she would spin upto 10000! Problem is runnin that throught the t50 gearbox is pretty #OOPS# house unless you have 50 gearboxs and enjoy changin them or u can afford the w series dellow bellhousing
Posted on: 2010/1/7 10:45
From Newcastle nsw
incase you didnt notice, i use to play with these in sprinters a few yrs back lol, and now im talkin about em, maybe a good option for my coupe lol :D
Posted on: 2010/1/7 10:46
(1) 2 3 4 5 »
