(1) 2 3 »
any info on a sr20de conversion for 1200?
From Sydney
hey guys just wanted to know if there are any info step by step on installing a sr20? i know its been done before but is there a page that i can read up on clearing firewall, fuel set up, mounting points, etc cheers guys
Posted on: 2010/5/2 6:16
Re: any info on a sr20de conversion for 1200?
From Adelaide, Australia
i did my own. tunnel needs to be cut bigtime but the xmember only needed the engine mounts cut, lowerd and i used ford cortina engine mounts. the stock s13 gearstick sits about where the handbrake is and the clutch master has to be moved/modded as the injection manifold is there. u can use a stock s13 radiator which is easily mounted
Posted on: 2010/5/2 8:34
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Sydney
sounds like a headache but worth it.
Posted on: 2010/5/2 9:21
well if u use an a series u would go through gearboxes. i recon L series is the way to go. fits in, weighs less than the sr and u can use a auto 120y tailshaft. lookup whitesedan he has done the L series
Posted on: 2010/5/2 9:50
Quite a regular
From ipswich
get a maddat crossmember, trans tunnel and brake booster with extended clutch resivior.... it will make things heaps easier, bit more expensive but makes the clearance issues easier, and definitly relocate the battery.
Posted on: 2010/5/2 9:53
1980 1200 ute SR20DE project
1992 N14 pulsar SR20DE
1986 navara king cab 2wd
Quite a regular
From ipswich
the L series is definitely the easier way to go and if i get another datto ill definitely be doing the L series over the SR but no regrets on the SR it has been a great learning experience so far... still got heaps to go
Posted on: 2010/5/2 9:58
From Sydney
sorry for nob question but whats a L series box? im unsure of this one?
Posted on: 2010/5/2 10:33
a lady with a very weird shaped moot:P its a L series engine gearbox
Posted on: 2010/5/2 10:40
From Sydney
which car did this one come from?
Posted on: 2010/5/2 10:52
From Geelong, Vic
any car with an L series in it, most of the mid to large sized datsuns from the early 70s to mid 80s
Posted on: 2010/5/2 11:03
(1) 2 3 »
