I was aiming for this engine in my vb10 but now supercharged A10 due to old age softening up.
The reason I like this M16A engine is because its like the g13b gti motor its replaces on the
GTI but made for rwd so all plumbinb is there for the front, Has Cosworth like head design and
valve mechanism no hydraulic tappets and no vtec or vvt (all other models of this capacity or
larger have it except for 2004-5 Liana)
It is in like an early 4age-copy but alloy, modern piston and crank coatings with higher
better port angles more like modern SR20 and bike engines.
From Liana with very low kms twin cam 16V and has RWD boxes that fit directly from the Suzuki
Jimny M13a series.
The specs are: 78mm x 83mm
1586cc (can be taken to 1996cc with 87.5mm sleeves)
123 bhp @ 6800 rpm (more with better inlet manifold and throttle body) 109 ft.lb @ 4800 rpm
I also have a spare 43,000klm head from the same model with no vvt to play with the porting and
manifold construction. I have 2 sets of flanges for both the inlet and exhaust manifolds.
The flanges are 12-14mm mild steel and alloy. The original inlet manifold is attrocious and the
first thing to look at making more power, flange can be used with a 4age inlet cut and shut or
other inlet manifolds of similar engines (eg. mitsu and hyundai)
my plan was to go full LPG turbo to rid any pollution gear and due to capacity limits for a 650kg car.
The engine was from an Auto Liana wagon with very low klms and so was the head so all parts are there
from top to bottom, you just need to use the flanges I supply to do the manifolding and find a Jimny
rwd M series gearbox (no transfer case like normal box) and a flywheel, clutch & starter from the same model. Also Megajolt jnr ignition kit about 200usd and fully re-programmable.
Also has the front water inlet/oulet setup, sourced from a Rwd setup. Looking at $600aud plus freight or pickup.
heres a site in taiwan that builds them up for more capacity but 123hp from 1.6 can be improved with better manifolds.
Some Swift owners are making 140+hp with tweaks in heavy 1100kg cars with power steering, air cond units.
So in a simple datsun setup no power steering and air con should present an improvement in hp.
http://www.topspindesign.com/consumer ... swift_1.9L/engine_kit.htmor 1880+cc kit by Monster Tajimas company
http://www.monster-sport.com/e/parts/eng_parts/m19kit/index.htmlEdit:
Engine sump has bulge at the front and the oil pump is in the front casing behind the
front crank pulley so out of the way of everything. The engine height is 1cm taller than
an A15, same length and similar width. Its very narrow in design and smoothly shaped.
Heres a pic of the Monster Rallye version 216+hp
