(1) 2 3 4 5 »
my a15 ute project
From dominican republic
hi all, im not from aussie but i love datsuns mostly 1200´s :D.
i have a white 1992 ute LHD i have now 2 years with it and i love it, i prefer a sedan but its dificult to find one in my country.
well 9 months ago i bougth an a15 for my ute, its a vannete a15 i know that because of the front pulley that had 3 belt passages the exhaust manifold is the big one y the inlet manifold is diferent and the rocker cover its different to.
i rebuild it, new pistons, rings, seals, bearings etc, i upgraded my transmision too to a 5 speed 60 series.
ok im running the 15 since september and its wonderfull, im using a 2 belt pulley cause i have air conditioner & an a12 carby with normal a15 inlet manifold and im not running mechanical fuel pump, i have electronic dizzy and it runs smooth and very well and i fell the diference of the a12 to a15 upgrade.
i really really love the A series engines and im not thinking on any engine upgrades for a long time but want to make my a15 more fun so i bougth a compe. oil pump with a cooler, a mitsu eci multi inlet manifold for efi setup, have a fuel pressure regulator, a toyota ct12 turbo, mitsubishi oem small intercooler and a few other stuff,
im thinking on making the efi setup with honda D16 engine ecu, wiring and stuff i have the p06 ecu that revs limit at 6500 rpm, i also made an A series to honda D series custom ignition support and im working on the custom inlet manifold, want to build the efi setup first then start to think on the turbo setup but its a low progress build cause i need to use my ute every week day
sooo, i dont know how many hp does it have but im going for at least 100hp or so, i hope i can get that from just the efi setup.
ive been focused on the exterior of my ute since i have it but now i want to get my a15 to the fullest on stock internals.
this will be my project tread so you can give me some advices.
cheers :D.
Posted on: 2011/2/16 2:55
Re: my a15 ute project
From south coast nsw
howzigoin dude, my advice is get some pics of your sweet little ute up asap.good to hear you keeping it A series.i just put an a15 into my ute and its awesome plenty of power without upgrading to huge brakes gboxes and diffs etc.my 2 cents:id go straight for some itb's bolted on to a dcoe manifold..nice cam,springs and ports and its hammer time!
Posted on: 2011/2/16 3:43
100hp is possible but you need a good cylinder head, like the GX head and revs like 6500 RPM.
The stock A15E engine was 92 HP ???
Do you have the Mitsu manifold that bolts to the A-series?
Posted on: 2011/2/16 4:02
greendog: thanks mate im in love with your ute, i have double valve spring but dont want to use bigger cam cause its to expesive and dificult to find in my country
also i have toyota trueno 4.30 diff at the rear with disc brakes and lsd and skoda favorit front strut inserts with front disks too and camber tops, 1-3/4 exhaust pipe
ddgonzal: im porting another head so i can use it for the efi setup and yes i bougth the mitsu manifold that fits A series i found it at ebay for just 50 dollars and it was complete
you can see the pictures of my ute in the photo album ( mpower )
i will post some other pics in here
Posted on: 2011/2/16 16:11
pictures of the engine bay paint and the lowered suspension
my plans are to finish the functional parts and then paint the entire ute
jpg  before.jpg (129.04 KB)
11179_4d5bfb6736821.jpg 800X600 px
jpg  after.jpg (126.20 KB)
11179_4d5bfb77b7ab7.jpg 800X600 px
jpg  66741654.jpg (138.57 KB)
11179_4d5bfba96616e.jpg 800X600 px
jpg  34848198.jpg (120.30 KB)
11179_4d5bfbb90de63.jpg 800X600 px
jpg  in the street.jpg (16.13 KB)
11179_4d5bfbe48ff69.jpg 800X600 px
Posted on: 2011/2/16 16:33
ha i love this thing its got the the best stance.are these pics with the old diff in?as the rears are tucked in nicely.u dont need licence plate in your town?
Posted on: 2011/2/16 19:40
From Rosewood, QLD
this thing is tops and i am a massive fan of that engine bay!
Posted on: 2011/2/16 20:13
1971 B110 sedan project.
2012 Nissan Micra daily.
It doesn't even look like it needs paint! your ute looks awesome, very well put together.....wheels, ride height, weather flares over the doors too!
Posted on: 2011/2/16 21:23
haha thanks to all of you greendog we dont need front license plate in here and the diff was shorttened
the rocker cover its going painted yellow anda other little things too
it needs paint cause it doesnt have clear on the paint
Posted on: 2011/2/16 22:46
speedo its crazzy it runs like 30kph more than normal :P why is that? i have 60 series 5 speed gearbox
and i would like to buy mira bumper so my ute can look like greendog´s ute
jpg  86.jpg (61.17 KB)
11179_4d5d686499cf2.jpg 1600X1200 px
jpg  87.jpg (88.36 KB)
11179_4d5d688ca90fd.jpg 1600X1200 px
Posted on: 2011/2/17 18:27
(1) 2 3 4 5 »
