[help] A15 Rpm tacho
From Canberra
Here is a quick question for you boys..
I am looking to put an RPM gauge into the ute, removing the clock but i want it to be accurate.
As from the tech wiki it states the A15 having - 67hp @ 5200 RPM
Now with my setup of:
Dual side draught webers 45mm
Genie extractors, 2.5 inch exhaust
CAMSHAFT 312-7.5
lightweight push rods
OVAL CYLINDER HEAD H75
Double valve springs
large 36mm valves
Roller rockers and collars
i am really unsure what the top RPM would be on the engine and what the hp reading is currently.. when would she redline?? is there a way i can work this out so when i put in a tacho it is accurate to the engine??
or is the best way to put it on a dyno and it will tell me??
Posted on: 2012/9/14 4:01
Edited by loosekid on 2012/9/14 5:10:15
Edited by loosekid on 2012/9/14 5:10:46
Re: [help] A15 Rpm tacho
Quite a regular
From Bellville, RSA
My mildly worked A14 is doing just shy of 8k... if that's any indication
Posted on: 2012/9/14 17:40
Datsun 1200 Sedan
From Snohomish, WA USA
8500-9000k. That's what my old A15 did with a worked motor. I think your cam is the key. Hard to say what your hp will be. Maybe 110-120hp. You'll have to get it dyno'd.
Nice setup.
Posted on: 2012/9/14 22:13
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
