« 1 (2) 3 »
Re: CAD files for manifold
From Hawaii, USA
the factory EFI manifold was a log manifold
and the performance was very good -- compared to the carburetor manifold it had no loss of power at low RPM, increased power at mid-RPMs and 15% more power at high RPM. And even just bolting a larger off-the-shelf throttle body on it increases the power
Posted on: 12/13 4:40
From melbourne
DD, upto what HP increase do you estimate with a bolt on CA20 throttle body ??
Posted on: 12/13 5:03
From Hawaii, USA
Andy & Geoff both tried larger TBs. Geoff found the RB20 unit was too finicky
jpg  A14E vs CA20E.jpg (29.59 KB)
174_5df6ab2a3fe61.jpg 674X340 px
Posted on: 12/15 21:52
From Queanbeyan nsw 2620
to he honest its a lot better in shape to the last runner then that other one people are buying that is a actual cylinder and the injector facing straight down where at least the injector on the factory one are at a angle looking straight at he valve and to be how much power do you think your going to make with 500hp I only offered it so its cheaper to buy and reliably. sorry
Posted on: 12/23 0:34
From Mordialloc
To give you idea on price for the whole EFI manifold made from a twin webber manifold using ALL NEW parts
ie: manifold ,bungs, rail, fittings, 10mm Aluminium base and end plates and getting a professional to weld the Aluminium plenum and bungs it will cost you about $750 (excluding injectors and throttle body which you could scrounge from the wreckers).
PS: you Can drill the bungs so the injectors point almost straight towards the valve
dp
Posted on: 12/23 5:54
keep it simple
From Melbored
if you braze the alum all yourself using HTS2000 alum brazing rods
on well roughened stainless brushed surfaces you can save a good
penny from asking a pro to rape you.
I did my alum pipe based bumperettes with different alloy brackets
and also repaired alum inlet manifolds with success.
Prob 400 aud all up is possible this way. The other way is harder
but I also did arc welded inlet manifolds for bike carbs that worked
well and for boost, plain steel is overlooked.
Posted on: 12/23 6:48
why you are slaves to Usury https://www.youtube.com/watch?v=FEheU28ea3c The Anzac Deception unknown by dumb Aussies http://www.anarchistmedia.org/pdf/The-Anzac-Myth.pdf ""
From Creswell, Oregon USA
I can produce billet manifolds for the 1200 for $750.00 ea.
Posted on: 12/26 21:24
An idea doesn't work unless you do.
Instagram @MD_Machine
From Mordialloc
I gather that is $US ? (then you have to add postage to AUS)
Posted on: 12/26 22:07
keep it simple
From melbourne
Add customs too
Posted on: 12/27 1:04
You guys have to pay a customs fee too?
Posted on: 12/27 7:10
« 1 (2) 3 »
