Gearbox ratios of the vanette 5 speed RS5W60A
From Sydney
Im wanting to know if by chance the input shaft and counter shaft from a vanette RS5W60A can be used in the FS5W60A sunny box. The input shaft in my FS5W60A sunny box is heavily worn through the case hardening and I was wondering if an input shaft from the vanette box would swap straight in and or the countershaft as well to keep it as a matched pair.
The ratios of the vanette box would help to indicate the tooth count of the input shaft. The sunny box has a tooth count of 20T on the input shaft.
Hopefully someone will have the hard facts on these boxes.
cheers
benny
Posted on: 2009/5/13 7:59
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Gearbox ratios of the vanette 5 speed RS5W60A
So Pitroad sells a FS5W60A tailhousing to convert RS5W60A to floor shift.
So I would think you could do the same, just swap the back of the transmissions. Then you back on the road.
See Tech wiki
Posted on: 2009/5/14 7:25
From Darwin NT
problem is he's got a 60L not a 60A
Posted on: 2009/5/14 7:40
current project 4x4 patrol...
From Sydney
I actually have several of both, Does anyone know the ratios of the Vanette box?
Posted on: 2009/5/14 7:57
1970 KB10 Coupe
S13 caliper b...
