perspex front windscreen for 1200. has anyone had one made
From brisbane. waking up the neighbours with the brap
as topic states above. has anyone had a perspex front windscreen. i have a drag 1200 ute and looking to get one made. my car doesnt have a windscreen at all and i need a template for it. can anyone help out
Posted on: 2010/4/29 23:29
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
Re: perspex front windscreen for 1200. has anyone had one made
From Townsville, Qld
here's a complementary question for that. You know in nascar and stuff where they have the retainer bars on the windscreen would you need a couple of those as well?
Posted on: 2010/4/30 12:33
From Melbourne, Oz
Dragg guys dont use them, I think in nascar its just because of the high likelyhood of larg debris at high speed
Posted on: 2010/4/30 12:36
"I hav achieved wood"
From Sydney, Australia
I would recommend you just get a windscreen.
Surely one of the SE QLD fellas has one. Otherwise, don't 'windscreen o'brians' still supply them?
Posted on: 2010/4/30 13:56
they do use them in drag racing. ive never seen a nascar datsun ute. ben bray has one on his datsun ute
Posted on: 2010/5/4 2:13
www.maddat.com.au
From Brisbane
i wouldn't use acrylic (perspex) i would recommend polycarbonate (lexan)
Posted on: 2010/5/4 2:50
AWD the way to go
From Rosewood, QLD
how much does it cost to make lexan windows?
Posted on: 2010/5/4 5:56
1971 B110 sedan project.
2012 Nissan Micra daily.
From Perth
I wouldn't use perspex/lexan/polycarb on a front screen
They are bastards to keep clean and any dust or crazing that they get will effect your vision
Especially if you drag at night
Stick with a glass screen ... your not really saving much effective weight and your buying yourself trouble
I looked into it with my 1000 racecar... glass is the way to go
Posted on: 2010/5/4 12:21
From Adelaide, Australia
New laminated glass windscreen cost $200 plus $50 to fit both front and rear glass in my car.
Posted on: 2010/5/4 12:36
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
i have got a windscreen now. also got a poly carb rear window made. had to with the back as the cage comes out the back window. front windscreen fitted was $200. and rear poly carb/lexen window was $55. this was easy fitted with the standard window rubber.
Posted on: 2010/5/4 22:47
www.maddat.com.au
