Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers measured this in inches. In metric, this is equivalent to a 4 x 114.3 PCD (Pitch Circle Diameter)
Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models and 1994 Sunny Truck models, used 12" wheels. Only the Datsun 1200 SSS used a special wheel.
Compatible Wheels
Anything that is 4-bolt on 4.5 inch circle fits (depending on tire size), although the offset on many front-wheel drive wheels is too much.
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13). Pefect for the front, but The may need a 1/4 inch spacer to clear the brake caliper brackets in the front
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Hyundai Excel
- Ford Laser (KA to KH)
- Rear-wheel-drive Mitsubishi
- Early SAAB (5.5 inch wide)
What WONT work:
- Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- Newer SAAB (900 Turbo)
Also same as Nissan Pintara. These are 14" wheels. aka "Pursuit" or "chaser" style rims as they are similar to police car (plain) steel wheels.
Don't pay more than $15 per steel wheel
The 5.5 wide wheels should fit.
The stock 6" and 7" wide Sillouettes won't fit the B110 or early B210 disc-brake strut. If you run Stanza or 240K struts, then no worries.
TRX Wheels
Discussion: will trx 15"rims fit straight onto 1200 ute without flaring?
"If I see another 1200 with TRX rims I'm going to smack you across the face!"
On standard Datsun 1200 struts they will require fairly low profile tyres, and quite large spacers for the front and it will need to stay at standard height. Even then you might find they are a tight fit and might grab the guard a bit if you hit any speed humps too quick or take corners quick.
If it is lowered at all you will need to roll the guards for sure!
With Stanza and other similar struts they fit no problem with 195/50R15 tyres and will only need to cut the front bottom corner out of the front guards for clearance when turning.
With Sunny (B310) struts on front and 195/50R15 tyres, it requires to roll all the guard lips, and run spacers on rear as they were scrubbing the inner guard and on all wheel arches the sharp lip all around the guard was tearing into the tyre slightly so rolled it right up.
Stock Wheel Comparison
| wheels | B110 | 1977 US B210 A14 | 1980 NA B310 |
| size | 4 J-12 | 4-1/2 J-13 | 4J-12 Canada w/A12A 4-1/2 J-13 5 J-13 (aluminum) |
| offset | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
| tire size | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
| balance (place weight on inside of rim) | 10gr or less (0.35 oz) | 11gr or less | 10gr or less |
| lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
Datsun Sunny B310 factory OPTION B & OPTION C wheels: 13" x 5"
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
ホイール
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Wheel Offset
The stock wheel is 4 inches wide with 30 mm positive offset (mounting face is 30mm outboard of the wheel's center line).
visually, the width of the wheel faces relative to the car's bodywork.
- Zero Offset - The plane of the hub mounting surface is even with the centerline of the wheel.
- Positive Offset - The plane of the hub mounting surface is shifted from the centerline toward the front or outside of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
- Negative Offset - The plane of the hub mounting surface is toward the back or brake side of the wheel's centerline.
- "Deep dish" old-school wheels have lots of negative offset
- FWD wheels typically have lots of positive offset
wheel offset and backspace diagram
Front-wheel-drive cars use wheels with high positive offset. This is to say that the mounting surface is far outboard of the wheel's center line. Often they will fit the 1200 if wheel spacers are used to bring the mounting surface back toward the wheel's centerline.
Stock Offset:
| model | Wheel type | Offset | wheel width | Tire width |
| B110 | steel | 30 mm (1.18 in) | 4" wide wheel | 155 mm |
| B210/B310 | steel | 30 mm (1.18 in) | 4.5" | 155 mm |
| B210/B310 | aluminum | 25 mm (0.98 in) | 5" wide wheel | 175 mm |
- Using B210 wheels on B110 results in a 1/2" (12.7 mm) wider overall rear width (measured by outside tire sidewall -to - sidewall). NOTE: These still fit under unmodifed B110 rear fenders.
- Steel vs. Aluminum wheels will have overall width 10-15 mm wider (tires are 10mm wider, wheels are 25.4 wider, but offset on each side in 5mm less)
Scrub Radius
Largest Sizes to Fit 1200
17-inch diameter wheels easily fit the 1200. The key is: width and overall height. Even 18" wheels are being used on 1200s with stock bodywork.
- 4.5": B310 13" +30 stockers won't fit the front of the 1200. They hit the brake calipers
- Reportedly 13x7 +0 fits perfectly
- For the widest wheels, use zero offset (generally)
- 6-inch wide wheels: most will not fit, but theoretically (with the right offset 0-5 minus) it is possible. Utes can fit wider wheels on the rear.
- 7" wide wheels require guards modification (they will rub on the fenders). With offsets of +10 at front and +2 at rears and all was fine but at full lock -- depending on the tires -- the fronts will probably scrub inside the guards
Rear
Rear wheel mounting flanges in Datsun 1200 reportedly can vary by 10mm side to side (see [http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=43865 offset diff housing alignment problem?).
- 7": 13x7 with 0 offset and they fill the gaurds perfectly
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
There is more room under the rear of the Datsun 1200 pickup model, compared to the sedans, wagons and coupes.
Wheel Adapters
Wheel Spacers
If the offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
Wreckers are your best bargain here ... lots of 13, 14, 15, 16 and 17" wheels, even some 12s. Lots of 12s avaiable in US junk yards.
- http://classicdatsun.com has Panasports
Manufacturers
- Konig makes a retro-style wheel with the proper offset for RWD application. Konig Rewind
Mail order
- tirerack.com
- Minilite Wheels - The real deal! alloy racing wheels 12x5 only $159 each in Silver, Black, White. Gold and Anthracite also available.
Also see: Wheel Weights
