A15 Engine
Revision as of 04:50, 14 January 2012; view current revision
Categories: A-series Engines | Engine Mechanical
The A15 is a 1488cc) engine produced from 1979 through 2209 (it is for sale in the 2009 Nissan C22 Vanette in Malaysia). The stroke was increased by 5 mm from the A14 engine's 77 mm to measure 82 mm. It produces 85hp. It used a different block casting but the same "tall-block" deck height as the A14. In the Roadstar it is capable of 49 mpg (17,3 km/L). A fuel injected version of the A15 (A15E) was offered in Asian markets.
[hide]
  • A15 ID Mark
  • Notice how the block extends above the timing cover by about 1 inch
Horsepower
From 67 to 80 HP
USA A15 lo-power fuel economy version with Automatic
Engine Family A140F
67 HP @ 5200 RPM (SAE)
A14 vs A15
A15 uses the second A14 block casting (same block as A14):
  • 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
    • Bore: 76 mm
    • Stroke A15: 82mm
    • Stroke A14: 77mm
    • Pin Height: The A15 piston has a 30mm pin to crown height, while the A14 has a 32.5mm height
Earlier A14 blocks were slightly different. The A15 oil pan has slight bumps in the side to allow the larger crank to swing without touch the pan sides.
  • Comparo: Early A14 block with Late A14/A15 block
Applications
  • 1974-1978 Nissan (commercial) forklift (Asian markets)
Datsun B310
  • 1979-1982 Datsun B310 (rear-wheel drive) a.k.a. 210, Sunny or 150Y
  • 1980-1982 Datsun N10 (front wheel drive) a.k.a. 310, Pulsar or Cherry
  • Nissan Vanette C120 June 1980- November 1988
  • Nissan Vanette C22 September 1985- June 1991
  • Nissan Vanette SS van & SE truck (S20) April 1994- 1999
Malaysia
  • Nissan Vanette C22 (1984-2009)
New Zealand
  • Sportstar and Roadstar utes (B120) from Nissan New Zealand 1980-1985
Nissan Malaysia
Brand new 2010 C22 Nissan Vanette.
470.JPG 471.JPG 1869.jpg 1870.jpg 7630.jpg 8022.jpg 10202.jpg 16259.jpg 17776.jpg
