Locks
Revision as of 08:07, 29 January 2013; view current revision
Category: Body
Datsun 1200 key locks include ignition, doors, trunk and fuel lid.
Also see:
* Bonnet Latch/Hood Lock
* Wheel Locks (Lug Nut lock)
* Keys
Datsun 1200 lock set: Door and fuel locks are all the same (Coupe/Sedan/Van/Truck)
Lock Set
1. Ignition lock cylinder (for steering lock type)
2. Trunk/boot lock cylinder
3. R & L door locks
4. fuel filler door lock. The fuel filler door is a faux lock.
Small clip is for the fuel filler door lock cylinder
Lock Set
B120 late
99810-G1500
A 48700-M1060 Ignition Switch for Steering Lock
B 80600-H1001 RH Door Lock
C 80601-H1001 LH Door Lock
D 76960-H7400 Fuel Lid Lock
Tawain made the Yulon 303T (Sunny Truck), so they have plenty of parts.
Yue Loong 301 (B210) Key Set
SUNNY B110/B210/120Y 1971-1979
80010-H5000 KEY SET Four pieces/set
* DOOR KEY DK-301R 80600-H5000
* DOOR KEY DK-301L 80601-H5000
* TRUNK LID TK-301 84460-H5000 (sedan)
* FUEL LID KEY FK-301 78840-H5000 76960-H5005 76960-H1001
B210 Japan
80010 CYLINDER LOCK & KEY SET
80690-E6000 HOLDER ASS'Y-key
25150-H5001 SWITCH COMP.-ignition & starter V (exc. SP-DX) -7412 > 25150-H5000
48700-H5000 LOCK ASS'Y-steering
48700-H5010 LOCK ASS'Y-steering
80600-H5000 CYLINDER ASS'Y-lock door (R.H.)
80601-H5000 CYLINDER ASS'Y-lock door (L.H.)
84460-H5500 LOCK ASS'Y-trunk lid K
84460-H5000 LOCK ASS'Y-trunk lid S
90600-H6600 CYLINDER LOCK ASS'Y-back door V <?> 90600-H6601
76960-H1001 LOCK ASS'Y-gas filler lid
76960-H7400 LOCK ASS'Y-gas filler lid (late)
JDM B210 steering lock looks like USA B110 type:
  • 80010-H5000 CYLINDER LOCK & KEY SET
  • 80690-E6000 HOLDER ASS'Y-key
  • 48700-H5000 LOCK ASS'Y-steering
  • 48700-H5010 LOCK ASS'Y-steering
B120
Key style shown here is '86 up.
Key Set
  • 80010-G1000 CYLINDER SET-lock & key (up to '71-3)
  • 80010-G1201 CYLINDER SET-lock & key (from '71-4)
  • 80010-G1005 CYLINDER SET-lock & key (from '73-9)
    • (注) 保 印は48年度保安基進改正に伴う変更および関連変更部品を示します。
  • 80010-G1004 KEY SET-CYLINDER LOCK 7510-7803
  • 80010-G1060 KEY SET-CYLINDER LOCK 7804-8109
  • 80010-G1900 KEY SET-CYLINDER LOCK 8110-
Key Set includes one of the following, and includes a key:
  • 25150-H1000 SWITCH-COMP-ignition & starter (up to '71-3)
  • 25150-H1010 SWITCH-COMP-ignition & starter (from '71-4 to '73-8)
  • 25150-G1001 SWITCH-IGNITION [for non-steering lock type] 7309-7803
    4-terminal switch
  • Or
  • 48700-H1600 LOCK ASSY-steering (up to '71-3) OPTION
  • 48700-H2010 LOCK SET-STEERING 7104-7803 OPTION
  • 48700-G1060 LOCK SET-STEERING 7804-8210
  • 48700-G1925 LOCK SET-STEERING 8211-
  • Steering Lock Set includes one of the following ignition switch:
    • 48750-H1900 SWITCH-IGNITION 7510-7803
    • 48750-E4700 SWITCH-IGNITION 7804-
Ignition Lock
See main article: Ignition Switch
  • 25150-H1010 SWITCH COMP.-ignition & starter STD, DX
    • 25157-H1001 BRACKET-ignition switch
    3-terminal switch
  • 48700-H2020 LOCK ASS'Y-cylinder [steering lock type] Coupe OPTION, S-GL, S-GX
    • 48700-H1900 ASSY-LOCK STEERING
    • 48700-H1901 ASSY-LOCK STEERING from 0471
    • Reversible key, left-handed
  • 80010-H1914 SET CYLINDER LOCK & KEY
USA B210 ignition lock is totally different. Clamps at mid-barell instead of end
  • 48700-H6200
    pictured with Ignition Switch attached
  • 80610-H6200 ASSY-HOLDER,WITH KEY
  • KEY00-00039 KEY-BLANK ST'G LOCK & DOOR
  • Removable lock barrel:
    • Standard Motor Products 1200 US-168L
For Steering Lock OR w/o Steering Lock
Ignition Lock
  • Steering Lock/Ignition Switch
    • STD 1200s have a simple ignition switch w/key cylinder
    • Other 1200s have a steering-lock/key-cylinder & seperate ignition switch
Door Locks
Door Locks
Door locks differ Right and Left side.
Aside from the plastic clip, the door locks fit:
B110
B120
620
E20
Trunk Lock
Coupe 84420-H1800 & 84430-H1800
Sedan 84420-H1000 & 84430-H1000
Van Back Door 90500-H1401+90805-H1400 & & 90600-H1401
    • Coupe 84420-H1800 & 84430-H1800
    • Sedan 84420-H1000 & 84430-H1000
    • Van tailgate 90500-H1401+90805-H1400 & 90600-H1401
Fuel Door Lock
1200 Fuel Door comes standard with a lock cylinder. It is non-keyed, so any double-sided Nissan key will open it.
See main article: Fuel Door#Lock
Electric Locks
Central locking kit
