Template:Diff ID
Revision as of 23:23, 16 March 2013; view current revision
Pre-1980
B10: H145, 3.900
 VB10: 4.111 (van/wagon)
 B20: 4.111 (ute/truck)
B110: H145 3.900
VB110: H145 4.111 (van/wagon)
PB110: H165 4.111
B120: H165 4.111 (ute/truck)
B210 1974: H145 3.900
B210 1975-up: H150 3.700 or 3.889
PB210/GB210: H165
B310: H150 various
A10: H165 various
1980-up
Axle Codes
H = Hitachi removable gear carrier (pumpkin/centre section)
HA - H145 (145mm diameter ring gear, 5.709 inch)
HA38 H150 3.889 ratio
HB - H150 (150mm diameter ring gear, 5.906 inch)
HC - H165 (165mm diameter ring gear, 6.496 inch)
HD - H190 (190mm diameter ring gear, 7.480 inch)
HE - H190 revision
HF - H190A
Axle code is on Chassis Identification plate 1980-on
Starting in mid-80s, Axle Code is on door-jamb sticker.
Counting
39 divided by 11 = 3.545 ratio
