Large 268 mm disc brake rotors from S110 or 280ZX can be adapted to B310 (Sunny/210) or A10 (Stanza/510) struts. Swap developed by Doug Morrisun.
This setup fits over most 13" wheels. Wheels with inside diameter less than 11.7" won't fit.
Rotors: 1980-1983 S110 (Gazelle/Silvia/200SX) Calipers: 1983-1990 Nissan B11/B12 (Sentra/Sunny) Adapter brackets: Morrisun Productions Brake hoses:
As these rotors fit over the hubs, it adds about 13mm to the total track.
B310 hub diameter: ~154 mm S110 rotor inside diameter: ~145 mm
Machining
S110 268 mm rotor & caliper requires some machining. But it gains ventilated rotors suitable for racing applications.
Stock hub is too large to fit inside the rotor hat
Machine outer diameter of hub down about 1/4"
Adapter
Buy or fabricate caliper adapter bracket to fit the 130mm bolt-spacing caliper to the 75mm bolt-spacing struts.
Adapts the B12 Caliper to the B310 strut.
Comparison
Rotor 268mm diameter this swap vs 245mm A10 Stanza JAP 252mm A10 Stanza AUS 252mm 280ZX vented front discs 250mm S13 Brakes Caliper 48mm single vs 48mm girling anette stock B310 A12-powered 51mm girling anette stock B310 A14-powered
Pads D275/D233 108mm vs D41/D104 58mm stock 1200
B310 pad![]()
D275/D233 pad![]()
Note: D275 is used by the factory Sunny Truck Disc Brakes, used with 208mm rotors to fit under 12" rims.
Parts
Rotors
The 268 mm rotors (NISSAN 43206-P6500/43206-R4800) are from the rear of:
USA 1979-1981 S130 "Datsun 280ZX" rear 1979-1981 S110 "Datsun 200SX" rear 1981 910 "Datsun 810" rear (except gasoline wagon)
JAPAN 1979 910 "Datsun Bluebird" October to December 1981-1982 C31 "Nissan Laurel" upper models
Only $16 from Rockauto.com * Centric 12142014 * Bendix PRT1181 * Beck/Arnley 0831750 * Raybestos 9225R * Wagner BD97313
280ZX USA catalog (Turbo or Non-turbo. 2+2 or Coupe) * 268 mm <-- this one * 43206-P6500 ROTOR-DISC BRAKE,REAR 0778-0881 (1979-1981 Model year) ** superceded 43206-R4800 0778-0881 * 258 mm <-- NOT this one * 43206-N9501 ROTOR-DISC BRAKE,REAR 0981- (1982-1983 Model year)
Specs
268 mm * 268 mm Diameter (10.565 inch) * Overall Height: 68.5 mm * Thickness (nominal): 9.6 mm * Thickness (minimum): 8.6 mm * Hub Reg: 68 mm * Bolt size: M12x1.25 (10.75 mm diameter) * Bolt circle: 4 on 4.5" (114.3 mm) * Weight: 5kg (11 pounds)
Lug Studs
Since the rotors fit over the hubs, they add about 1/4" to the mounting face of the wheels. So you *may* need slightly longer Wheel Studs, which are common from a wreckers or buy them new.
See 280ZX_Brake_Upgrade#Lug_Studs
