Console
Revision as of 10:10, 23 January 2015; view current revision
Category: Body
Datsun 1200s were fitted with various consoles including full-style and auto/ute style.
Full Size
Full size console was usually fitted with a Clock, as the Tachometer was rightly fitted into the dashboard. But you can put a tach in the console if you so choose.
21477.jpg Foam block on underside
21478.jpg Brackets
592.jpg w/o heater
6595.jpg SSS 2129.jpg GX
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
  • 74980-H2010 ASS'Y-CONSOLE BOX [full, fitted to GL manual models]
  • 74980-H2020 ASS'Y-CONSOLE BOX [full, fitted to GL automatic models]
1971-12 Japan [Facelift] catalog
  • 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL 4-speed
  • 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
1971-4 Japan catalog
    • 79482-H1801 FINISHER-console box
  • 27389-H2300 SPACER-rubber (fixing clock to console box) (op.) ALL
USA Catalog
  • 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
  • 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
  • 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
Mask
'Sunny'
25005-H1800 MASK-tachometer [instrument panel]
74990-H2021 MASK-clock [console]
 85-13412-1 SCREW 3
 89-15434-1 WASHER-plain 3
'Datsun'
25005-H1810 MASK-TACHOMETER "DATSUN" [instrument panel]
74990-H1800 MASK-CLOCK [console]
 08513-41212 SCREW 3
 08915-43410 WASHER-PLAIN 3
Excellent
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also these unique 3-gauge versions. For more, see: PB110
2010.jpg PB110
9020.jpg 1971
7712.jpg PB110s could also come with regular-style gauge layout
460.jpg 1972 Facelift
Short Console
The short pocket-type console was fitted to:
  • USA Automatic 1200s
  • JAPAN non-GL automatic (GLs autos used a full console)
  • JAPAN 3-speed column shift OPTION
  • B120 Pickups as standard equipment (except STD models)
Console Boot for shift lever (aftermarket)
シフト ブーツ
Full and short consoles use the same shifter boot.
  • G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
1971-4/12 Japan catalogs
  • 74980-H1801 ASS'Y-CONSOLE BOX, with bracket 4-speed (ex. GL, GX)
    • 74982-H1801 FINISHER-console box
    • 74986-H1801 ASS'T-BOOT
  • 74980-H1021 ASS'Y-CONSOLE BOX, with bracket A-all (ex. GL)
North America catalog
  • 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC
  • 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC
B120 1974 Catalog
  • 74980-H1801 BOX ASS'Y-console, with bracket [Black]
    • 74982-H1801 FINISHER-console box [chrome trim]
    • 74986-H1801 BOOT ASS'Y
    • 08510-61642 SCREW (8)
    • 08915-43642 WASHER-plain (4)
    • 01241-00061 NUT-spring (4)
B120 1997 Catalog
  • 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET 7510-7803 [Black]
  • 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
  • 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
  • 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910
  • 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
  • 74982-H1801 PANEL-CONSOLE A 7510-8109 [trim]
  • 74982-G1900 PANEL-CONSOLE A 8110-8910 [Chrome trim] K504
  • 96930-95W00 PANEL-CONSOLE A 8910- [gray trim]
  • 74986-H1801 BOOT-CONSOLE 7510-8109
  • 74986-G1160 BOOT-CONSOLE 7804-7907 DARK BROWN
  • 74986-G1660 BOOT-CONSOLE 7908-8910 BROWN
  • 96935-95W00 BOOT-CONSOLE 8910- GRAY
  • 74987-H1801 BRACKET-CONSOLE FRONT
    • 08510-61642 SCREW (2)
      • 08961-13240 NUT (2)
    • 01241-00061 NUT (2)
      • 08510-61697 SCREW (2)
  • 74988-G1160 BRACKET-CONSOLE REAR
Fibreglas
Glassfibre versions
Aftermarket
Amco aftermarket/dealer installed
Custom
Portugal 1200s. Are the custom consoles?
Documentation
1555.jpg JDM 2209.jpg USA
Alternative Sources
Honda Civic
Barina
Barina
B210 Console
Does not fit the 1200 well
B210 console
74598-H5000
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
838.jpg 1350.jpg 834.jpg 3069.jpg 4748.jpg 4823.jpg 4939.jpg 5619.jpg 9471.jpg 21466.jpg 21467.jpg 21471.jpg 21472.jpg
click
click
click
keywords: コンソール
