Carburetor Overview
Revision as of 20:46, 5 May 2015; view current revision
Categories: Fuel System | Hitachi 306 Carburetor
The Datsun 1200 uses a Hitachi carb, model Hitachi DCG-306 (manual choke) or DCH-306 (automatic choke). This is a modern, two-barrel progessive linkage carburetor. It used bore sizes of 26/30 and venturis of 20mm (primary) and 26mm (Secondary). Datsun 1200 GX models used twin Hitachi 38 sidedraft carburetors with a manual choke system.
Links
Hitachi DCx carbs were used on, among others:
  • 67-70 Datsun B10
  • 71-73 Datsun B110
  • 74-78 Datsun B210
  • 79-82 Datsun B310
  • 73-75 Honda Civic
  • 76-79 Mazda (model?)
See Also:
NOTE: The B10 Datsun 1000 used a smaller carb, the Hitachi DCG-208.
ID boss:
DCG-306
DCG is the manual-choke series.
1971 vs 1972
DCH-306
DCH is the Automatic Choke series.
1977 USA
Vacuum Secondary
DCH-306 with vacuum-operated secondary throttle. 1981-1982 USA models.
Late A12
This is the carburetor on 1989-1994 JDM A12 engines.
Factory Nissan 1200 ECU controls the electronic feedback carb via input from O2 sensor.
22604-95W00
FBM-N13
DCK
