Engine Gasket Kit
Revision as of 00:27, 20 July 2016; view current revision
Category: Catalog
Nissan Gasket Kits
10101 full engine gasket kit
      contains head set + other engine gaskets
11042 Head Set (valve regrind set)
      every thing needed to change a head
11044 cylinder head gasket
10101
GASKET KIT-ENGINE REPAIR
* 10101-H1027 GASKET KIT-engine [1970-1973 A12] $208 USD
10101 includes:
Head Set (REGRIND) Gasket Kit
* Head gasket
* Valve Cover gasket
* Thermostat gasket
* Valve Seals
* Manifold Gasket Intake/Exhaust Manifold gasket
* EGR gaskets
Other Seals Included in Engine Kit
* Timing Cover gaskets & Seals
* Fuel Pump gaskets
* Oil Pump gaskets
* Distributor O-ring
* Crankshaft seals
* Water pump gasket
* Oil pan gaskets
Aftermarket
Your local auto parts store carries non-Nissan gasket sets of various manufacture.
Or, buy at RockAuto.com
DJM FGS6004 comes with wet and dry manifold gaskets
ITM 09-00526.jpg comes with round-port and oval-port gaskets
174_578ebe3296968.jpgPost 479988
11042
A15 North America Head Set (B310)
11042-H9527 KIT-VALVE REGRIND A14,A15(CAN) -    	             2 11042-H9526
11042-H9526 KIT-VALVE REGRIND A14,A15(CAN) 0880-    	             2 11042-H7226
11042-H7226 KIT-VALVE REGRIND A14,A15(CAN) 0879-0780	             0
11042-H8927 KIT-VALVE REGRIND A14,A15(USA) -    	             2 11042-H9826
11042-H9826 KIT-VALVE REGRIND A14,A15(USA) 0880-    	             0 11042-M6726
11042-H9527 KIT-VALVE REGRIND A14,A15 CAL A14 FED(KFU) A14 CAN -0779 2 11042-H9526
11042-H8927 KIT-VALVE REGRIND A14,A15(USA)                           2 11042-H9826
11042-H7227 KIT-VALVE REGRIND A14,A15 FED (EXC KFU)	       -0779 2 11042-H7225
11044
B310 North America Catalog
11044-H9821 GASKET-CYLINDER HEAD      A14,A15 0880- 2 11044-H9802
11044-H9820 GASKET-CYLINDER HEAD      A14,A15 0880- 0 11044-H7201
11044-H7201 GASKET-CYLINDER HEAD      A14,A15 -0780 0
13270-H1000 PACKING-ROCKER COVER      A14,A15
11132-H5025 GASKET SET-OIL PAN        A12A,A14,A15
13044-H1000 GASKET-TIMING CHAIN COVER A14,A15
