Hand Brake
Revision as of 18:55, 27 June 2018; view current revision
Category: Brake System
Datsun 1200 has a service brake system with the handle conveniently located between the two front seats. Also known as "emergency brake" or "hand brake" (the primary brakes are called the "service brakes").
74965 Handbrake cover is called by Nissan the "parking brake lever COVER".
26363.jpgAlbum 26363
36310 Hand Brake Lever Assembly (comes in black, brown and grey)
36315-H1001 Hand Brake Handle
36402 front handbrake cable
36400 rear cable (complete set)
UTE: Parking Brake Cable goes out the back wall
26409.jpgAlbum 26409
Hand Brake Cover
74965-H1000 original type
26363.jpgAlbum 26363 hbc-.jpgAlbum click to view hbc.jpgAlbum click to view 4489_5ac16b31bab35.jpgPost 487963 4489_5ac16b3e1fddc.jpgPost 487963 4489_5ac16b447ca2b.jpgPost 487963
B210 cover also fits.
Top: replacement part, same as B210 | Bottom: original B110 design
8190.jpgAlbum 8190
ブレーキカバー
Cable Routing
Front half is same for all 1200
21610.jpgAlbum 21610
Rear half
9389.jpgAlbum 9389
Coupe
2886.jpgAlbum 2886
sedan
9390.jpgAlbum 9390
9391.jpgAlbum 9391
Ute - cable comes out the cab lower rear panel
13738.jpgAlbum 13738
Dash-top Indicator Lamp
Some utes had a PARK BRAKE lamp on top of the dash that lit up when the handbrake was activated and IGN was ON.
26134.jpgAlbum 26134
26133.jpgAlbum 26133
18685.jpgAlbum 18685
Light Switch
See main article: Brake Wiring#Hand Brake Switch
Also see: Hand Brake Part Numbers
  • 74965-H7300 BOOTS-HAND BRAKE [Large style]
    22106.jpgAlbum click to view
    • replaced: 74965-H1000 BOOT-HAND BRAKE B110 [small style]
      26363.jpgAlbum click to view
  • 74965-H1000 COVER ASSY-PARKING BRAKE LEVER B120 8910-
  • 74965-G1060 B120 7804-8910 [Brown]
  • 36011-89901 SWITCH-HAND BRAKE USA
  • 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
    • Also fits B210 USA
    • Also fits B210 JAPAN from '75-4
Aftermarket Cable
  • 48-1/4" Overall Length, 2 Per Car
  • RAYBESTOS BC92888 $39.79
  • ACDELCO 18P154, 18033072 $48.79
21472.jpgAlbum 21472 21471.jpgAlbum 21471
B140
2005 bakkie with Bench Seat has the hand brake lever next to the door.
22420.jpgAlbum 22420
