License Lamp
Revision as of 05:42, 5 September 2018; view current revision
<-- Back To: Lighting System
Each body style (sedan, coupe, wagon) uses a different kind of number plate lamp. Truck uses the coupe type.
The type of lamp corresponds with the bumper type.
#Coupe lamps are above plate, under the bumper
#Truck lamps are above plate
#Sedan in bumper top edge
#Sedan side-lit
#Van above number plate in tailgate
Sedan
Sedan light fits into the top of the bumper, and illuminates the plate from below.
11174.jpgAlbum click to view 1208.jpgAlbum click to view 16172.jpgAlbum 16172
South Africa (510-style bumper)
17111.jpgAlbum 17111
H10 Assembly
20725.jpgAlbum 20725 26510-H1000-.jpg 26510-H1000_.jpg 26510-H1000.jpg Cover frame is marked "IKI 6001 JAPAN"
Lens is marked "SAE L70 IKI 6001 JAPAN"
20726.jpgAlbum 20726
L70 = License Plate Lamp, 1970 specification SAE J759
27140.jpgAlbum 27140
26510-H1000 LAMP ASS'Y-licence
* 10W bulb
* 26511-H1000 LENS
* 26512-H1000 COVER
* 08310-41420 SCREW (2)
* 26513-H1000 PACKING
Green wire/White stripe with the typical B110 bullet connector. See Lamp Wiring
27141.jpgAlbum 27141
Sedan Update
For USA market, the rear number plate light changed in 1973 to meet higher government standards of illuminating the plate. Coupe license lamps already were bright enough, so only the sedan was updated.
Early license plate lamp (on top of bumper):
2120.jpgAlbum 2120
Late license plate lamp (dual lamps on either side of plate):
1427.jpgAlbum 1427
Coupe
Lamp type #H18 is used coupe & ute
Two are used on each coupe, hidden under the bumper, one above each license plate bolt. You can see the holes in this photo:
14005.jpgAlbum 14005 5287.jpgAlbum 5287
Coupe lamps are not normally visible until turned on, because they are up under the bumper.
Pickup
Datsun 1200 ute uses same license lamp as the #Coupe.
Type #H18 lamp marked "SAE L 69", "IKI 6003" and "JAPAN" and "E4 455"
Placement: Like the coupe they are hidden from normal view, except instead of the bumper, they are under the Lower Rear Panel.
20728.jpgAlbum 20728 23214.jpgAlbum 23214 10819.jpgAlbum 10819
H18
Type H18 lamps are used by #Coupe and #Truck
20724.jpgAlbum 20724 20727.jpgAlbum 20727
Marked "SAE L69", "IKI 6003" and "JAPAN" and "455"
26510-H1800 LAMP ASSY-LICENSE (市光 ICHIKO) 2
26715-89901 7.5W bulb
26511-H1800 LENS-LICENSE LAMP
26513-H1801 PACKING-LENS
Lens needs cleaning?
20722.jpgAlbum 20722 20723.jpgAlbum 20723
27144.jpgAlbum 27144
Wagon
VB110 uses a single large chrome license lamp just above the number plate:
638.jpgAlbum 638 4489_49e6ef4cca9d9.jpgPost 251089
26510-H1400 LAMP ASS'Y-license
* 26517-H1400 PACKING
26511-H1400 LENS (2)
* 26513-H1400 PACKING (2)
* 7.5W bulb (2)
ライセンス 灯 ナンバー
ライセンス ランプ 26510-H1800
