Nissan wheels
Revision as of 19:39, 9 July 2019; view current revision
Category: Wheel And Tire
<-- Back to Wheels (includes 1200 & Sunny wheels)
R30 Rims
15 X 6 Skyline#R30 wheels, 20-spoke hurricane-type. #R31 Skyline was 24-spoke
4020.jpgAlbum 4020 400px-1984_Nissan_Skyline_%28R30%29_Ti_Special_Edition_2.4E_hatchback_%2825977751876%29.jpgWIKI go to Wikipedia 13358.jpgAlbum 13358 5514.jpgAlbum 5514 5162.jpgAlbum 5162 8236.jpgAlbum 8236 10535.jpgAlbum 10535 3196.jpgAlbum 3196 3194.jpgAlbum 3194 10308_4f7d6ccfd7cee.jpgPost 403014 17004.jpgAlbum 17004
R31 Skyline
See Main Article: R31 Wheels
th_R31-silhoutte.jpg th_R31_Silhouette.jpg th_Gts1-wheel.jpg th_425px-Gts2-wheel.jpg th_40300-J7111.jpg th_15x630_R31.jpg
R31 Skyline spare steel wheels
"Pursuit/chaser" style wheel may be used on Datsun 1200.
See Main Article: Pursuits
R32 Skyline
5-lug
8" wide, fit with PCD adapters?
11543.jpgAlbum 11543 400px-Nissan_Skyline_R32_GT-R_001.jpgWIKI go to Wikipedia 13493.jpgAlbum 13493
R32 GTS wheels 16 x 6.5 with 205/40R16
20878.jpgAlbum 20878
GTS 18 x 8.5 front, 18 x 9.5 rear
12350.jpgAlbum 12350
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims. Looks like Bridgestone#Zona Special Antares.
SSS wheels reportedly not fit 1200 without spacers.
11098_4e229c93e2f27.jpgUpload click to view 174_5a505db957ab7.jpgPost 487146 12575.jpgAlbum 12575 13632.jpgAlbum 13632 7642.jpgAlbum 7642 552.gifAlbum 552 10421.jpgAlbum 10421 25129.jpgAlbum 25129 25128.jpgAlbum 25128 7145.jpgAlbum 7145
C22
USA C22
40300-V6104 5.5-JJX14 +40 <> 40300-V6120
40300-V8000 SPARE <> 40300-V8077 [8-hole steel]
40300-17C25 AL [turbine]
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
810
Datsun 810 Bluebird/810/200B/180B
12484.jpgAlbum 12484 12486.jpgAlbum 12486
14" styled steel wheel | 13" 8-slot steelie
1274.jpgAlbum 1274 27072.jpgAlbum 27072
C-type 13" (also used by S10) & E-type 14"
23743.jpgAlbum 23743
A-type 5.5x14
40300-R4625 with nut set KOHBE <> 40300-U9625
40300-R4626 with locking nut set KOHBE <> 40300-U9626
40300-R4671 40300-U8925 A-type 14" (export option)
A-type
Datsun 810 factory OPTION B & OPTION C wheels: 13" x 5"
23907.jpgAlbum 23907
B-type 6-spoke
40300-U7527 B-type 5Jx13
40300-U7528 B-type 5Jx13 locking
C-type 8-slot
40300-W6027 C-type 5Jx13
40300-W6028 C-type 5Jx13 locking
B-type
Australia 200B Aspen GL (optional GX) 14x6 (20-spoke)
2473.jpgAlbum 2473 951.jpgAlbum 951
E-type 32-spoke SSS, LN 5.5JJx14
40300-S0625 with nuts
40300-S0626 locking nut
200B SX (32-spoke) 14x6
3542.jpgAlbum 3542 1438.jpgAlbum 1438 3627.jpgAlbum 3627 25700.jpgAlbum 25700 3143_49cf5554603f5.jpgPost 248862
910
AUS/JAP Bluebird
14" steel 8-slot/8-square hole
7097.jpgAlbum 7097
USA 910 "Datsun 810" and "Maxima"
40300-N8810
40300-N8870 <1>  40300-N8804
40300-W1000
40300-W1004 <5>  40300-W1014
40300-W1070 <5>  40300-W1004
40300-W2426
40300-W2428
40300-W2426
U11
1985-1988 U11 Maxima used 15x6 +40 wheels -- same dimensions as #S13 wheels. They use the Datsun bolt pattern 4-on-4.5" (114.3mm). Can be used on 1200s by utilizing wheel spacers. 1987-1988 came with 15x6+40 wheels in 4-lug and 5-lug versions.
16-slot turbo/aero wheels
nissan-maxima-wheels-62271-b.jpg 400px-1987_Nissan_Maxima_rear.jpgWIKI go to Wikipedia
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See Main Article: TRX_Wheels
Pulsar
Nissan Pulsar/Cherry/Langley, FWD small car.
N12
Pulsar N12 4.5x13 FC/FL/SSS/GF (Prince Liberta Villa, sold by Nissan Bluebird Shop)
?40315-01M20 WHEEL DISC ORNAMENT
22948.jpgAlbum 22948 22949.jpgAlbum 22949
Pulsar N12 5Jx13 Alumi
40300-01M25/40300-01M26/40300-01M28/40300-01M85/40300-01M86/40300-01M88
40300-01M70/40300-01M76
13x5
20200.jpgAlbum 20200
N12 ET
The Pulsar ET was the sedan/multiback version of the N12 Turbo, and came with the legendary E15ET engine. (The coupe version was the EXA, or NX in USA)
3170.jpgAlbum 3170
651.jpgAlbum 651 6040.jpgAlbum 6040
Pulsar ET Turbo - 14 x 5.5
174_56ef99aaecb10.jpgPost 477480 3786.jpgAlbum click to view
EXA
The EXA was the coupe/sporty version of the Pulsar Turbo, and the N13 EXA came with the legendary CA16DE or CA18DE engine. Badged "Pulsar NX" in USA (SE with CA, XE with E15/G16).
EXA wheels N12 or N13 ???
3575.jpgAlbum 3575
Similar
4517.jpgAlbum 4517
For 24-spoke, see Cheviot Classic 13x5.5
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
8-hole aero fan
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30
slanted 8 slot
15 x 6.5 +25
4 on 4-1/2 bolt circle
Pilot hole diameter 66 mm
23 lbs
left & right wheels
F31 Japan
8602-8808
 14x5.5+30 7-slot styled steel
   40300-58L05 8602-8702 VG20 [F31,C32]
   40300-58L07 8702-8808 VG20 [F31,C32]
 15x6+30 10-slot styled steel
   40300-59S00 8602-8702 V20T.XS [F31,C32,R31]
   40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31]
               8808-9805 VG20E *(VG20DT+VG30#)
   40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31]
8602-8808 spare steel 4x15 4-slot
  VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15
  VG30.ULTIMA 40300-59S15 8602-8808
  ALL 40300-59S15 8808-
8602-8603- alloy 8-slant/spoke 6.5x15
  40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E
  40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E
  40300-F6627 LH <> 40300-F6225
  40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS)
  40300-F6527 LH
Spare Tire
15x4T+40
40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15
* C23 Vanette
* M10/M11 Prairie
* S12/S13/RS13 Silvia
* W10 Avenir
* T12/T12Y Violet/Stanza/Bluebird
* A31 Cefiro
* F31 Leopard
* R31/R32 Skyline
* C32/C33 Laurel
* P10/P10E Primera
* U11/U12/U13 Bluebird
40300-28E15
174_574a4b609f2cc.jpgUpload click to view
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15
* B15
* C23
* K30S
* P11/P11E
* R33
* RS13/S14
* U14
* W10/WP11
* C34
* U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS
40300-N8810 4TX16 SPARE
40300-N8900 5JX14 0179-0783
40300-N8910 5JX14 0781-1081
40300-N8427 5.5JJX14 AL [16-spoke]
40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25]
40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]
40300-S6027 32-spoke hurricane
S13
?40300-15U28 15X6JJ silver Hitachi [K504]
* RS13 Type-X 9505- option
* R33 some
* S14 option K.2WS.QS
8233.jpgAlbum 8233
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole
* Base: 195/60R15
* SE: 205/60R15
10-hole Spare
15" x 4", 4 Lug, 4.5" Bolt Pattern
https://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/th_nissan-240sx-wheels-62253.jpg
40300-50F26 silver top 15x6JJ+40 7-star
* RS13 (S13 Hatchback/180SX)
* A31 aero type silver
* C33
* R32 including V Selection 2 and 60th Anniversary
9360.jpgAlbum click to view 9361.jpgAlbum click to view
9333.jpgAlbum 9333 9362.jpgAlbum 9362
Z-car Rims
Datsun S30  "Fairlady Z" or 240Z/260Z/280Z
Datsun S130 "Fairlady Z" or 280ZX
See Main Article: Z_Rims
th_280zxt.jpg th_40300-P8185.jpg th_40300-N3200.jpg th_40300-03P25.jpg th_62172used.jpg th_62143goldto.jpg
