Sedan Grille
Revision as of 20:27, 23 October 2021; view current revision
Category: Body
<-- Back to Grille
Datsun 1200 Sedans were originally fitted with a stainless metal grille. Early 1200 Pickups (1971-1977) use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Original Grille
1970-1971 Sedan Grille. Early 1200 truck used this through March 1978. Export 1200s used this into 1978.
4747.jpgAlbum 4747
25357.jpgAlbum 25357
Sedan
1205.jpgAlbum 1205 5414.jpgAlbum 5414 737.jpgAlbum 737 17977.jpgAlbum 17977 18381.jpgAlbum 18381
Van
8621.jpgAlbum 8621 4910.jpgAlbum 4910
Early Truck
9917.jpgAlbum 9917 i312487.jpgIMCDB click to view
15804.jpgAlbum 15804 10229_4a48b9e3341bc.jpgPost 260517
Head Lamp Rim
Headlamps surrounds aka eyebrow trim aka finisher
7952_53d7532bd4593.jpgPost 458474
ASSY-RIM,HEAD LAMP, RH
ASSY-RIM,HEAD LAMP, LH
26364.jpgAlbum 26364 26365.jpgAlbum 26365 174_4fe1528e0d295.jpgUpload click to view 10229_4a48b8e990589.jpgPost 260517
Rim with side-moulding
5239.jpgAlbum 5239
SURROUND moulding-RADIATOR GRILLE, SIDE, RH
SURROUND moulding-RADIATOR GRILLE, SIDE, LH
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
  • Japan market 1200s used "S" mark
  • Export market 1200s used "D" mark
917.jpgAlbum 91710401.jpgAlbum 10401 11318.jpgAlbum 11318 6001.jpgAlbum 6001
Stainless grille with Facelift Grille emblem
23189.jpgAlbum 23189
Fitting
Click for full size pictures of the grille mount points:
19565.jpgAlbum 19565
19558.jpgAlbum 19558
grille mounts on Core Support
174_517063e76a3ec.jpgUpload click to view
And the eyebrow trim mount points:
19562.jpgAlbum 19562
Fitting to Others
Fitting Sedan grille is done in Japan to many Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit the Sedan grille to a Coupe.
  1. Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
    19559.jpgAlbum 19559
  2. Fit two thin brackets to back of sedan grille
    19560.jpgAlbum 19560 19572.jpgAlbum click to view
  3. Drill four holes in radiator support to correspond to the holes in the sheet bracket
    19573.jpgAlbum 19573
    • Drill them 20mm to the side of the headlight rim screw holes
  4. Screw sheet loops to front of car
  5. Screw grille to sheet loop ends
Also see: POST demacoz changeover photos
Installing Round Headlights in Late Truck
20859.jpgAlbum 20859
Fit the headlight Rims (easiest to do with grille off car)
  1. coupe and late ute are missing the outer bracket:
    19566.jpgAlbum 19566
  2. All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
    96706-B0700 GROMMET for screw
19567.jpgAlbum 19567
(1-3) ASS'Y-grille, radiator
62302-H1003 Sedan (exc. GX), Van, Truck DX -7803 $169.65 USD
62302-H2300 Sedan GX
62302-G1000 Truck STD [painted]
(14-19) ASS'Y-RIM, head lamp (Eyebrow Trim\head lamp Rim)
62320-G1000 STD SUNNY TRUCK RH 1971-1975 [NON-CHROME]
62321-G1000 STD SUNNY TRUCK LH 1971-1975 [NON-CHROME]
62320-H1002 chrome (R.H) $39.17 USD
62321-H1002 chrome (L.H) $39.17 USD
26208.jpgAlbum 26208
(20-25) Surround Trim Coupe, Sedan and Van, Truck
62322-H1001 SURROUND-radiator grille, upper $40.27 USD
62323-H1001 SURROUND-radiator grille, lower $27.13 USD
62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD
62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
LOWER SURROUND
11813_4abe0b34cc8f6.jpgUpload click to view
Core Support Panels
1972 Minor Facelift
The 1972 Japan-market facelift introduced a new grille for sedans and vans. It featured a wire mesh insert. This was also used for South Africa production, while the rest of world continued with the original (stainless) grille.
22827.jpgAlbum 22827
1523.jpgAlbum 1523 752.jpgAlbum 752 457.jpgAlbum 457
62302-H7200 black GX with square mesh
22826.jpgAlbum 22826
62302-H3100 STD, DX and GL grille [Argent] with square mesh
7522.jpgAlbum click to view
67829 62302-H3100 Grille with honeycomb mesh
1972_Grile.jpgPost click for topic
1972 Van
South Africa GX version with 'D' badge
16695.jpgAlbum click to view
17113.jpgAlbum 17113
Retro-fitted to Sunny Truck:
18254.jpgAlbum 18254
1972 Sedan grille fitted to a coupe:
17958.jpgAlbum click to view
17432.jpgAlbum 17432 17529.jpgAlbum 17529 17957.jpgAlbum 17957
Emblems
Main: Badges
CENTER ORNAMENT & TRIM BADGES
22828.jpg 22513.jpg 28127.jpg yunakiti-img600x450-1277628693ok47g777311.jpg 62330-H7225.jpg
Parts List
62380-H3215 inserts (2 needed)
cast marked "62380-H3100"
Customized
