Engine
Revision as of 22:10, 30 April 2025; view current revision
Categories: Engine Mechanical | A-series Engines
The Datsun 1200 came only the Nissan A12 engine, a nominally 1200 cc engine that matches its name (it is actually 1171 cc). This four-cylinder A12 engine is a superb little economy engine with good performance and legendary reliability.
27017.jpgAlbum 27017
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
See also: A12 engine for more details about A12 Engine
The Datsun 1200 came only the Nissan A12 engine, a nominally 1200 cc engine that matches its name (it is actually 1171 cc). The A12 debuted in 1970 in the first Datsun 1200, and is a redesign of the earlier A10 engine used in the Datsun 1000. It is a traditional type inline 4 cylinder, with overhead valve cylinder head. The A12 engine is a superb little economy engine with good performance and legendary reliability. The Datsun 1200 GX trim model came with a Twin Carburetor version of the A12, the A12GX Engine.
The A12 is a four-cylinder inline engine (a straight engine i.e. I4 or L4).
400px-Reihenmotor_Vier_Zylinder_1-2-4-3.gifWIKI go to Wikipedia
The advantage over a boxer (flat) four-cylinder (famously used by Porsche, Volkswagen and Subaru) is that the inline four has a single cylinder head, meaning it is simpler to maintain. And it has less vibrations (is better balanced) than the relatively uncommon V4 design used in motorcycles and in 1960s/1970s Ford/Volvos. While an inline four is not a perfectly balanced design, the small bore of a 1.2 liter class engine is pretty smooth (balance shafts are often used with larger fours). Contributing to the A12 smoothness is that the Datsun engines are precision "balanced and blueprinted" at the factory — unlike the engines from many other manufacturers.
A12 Engine (single carburetor engine)
1204.jpgAlbum 1204
A12 GX Engine (twin carburetor engine)
11789.jpgAlbum 11789
A12 Engine ID Mark
Removal And Installation
Disassembly
Ever wonder how the engine comes apart?
Engine Tips And Tricks
Engine Buildups
