Workhorse
Revision as of 05:19, 26 November 2025; view current revision
Category: Documentation
<-- back to South Africa Brochures
26709.jpg#Werkesel 29636.jpg#Workhorse
Werkesel of Pretperd
1990 Bakkie-Kar, Nissan's 1400 1/2-tonners - It's bred to work but loves to play
IT'S BRED TO WORK BUT LOVES TO PLAY
WERKESEL OF PRETPERD workhorse or fun horse
26709.jpgAlbum 26709
OUR AMAZING BAKKIE-CAR. NISSAN'S 1400 1/2-TONNERS.
ONS VERSTOMMENDE BAKKIE-KAR. NISSAN SE 1400 1/2-TONNERS.
NISSAN
26710.jpgAlbum 26710 26711.jpgAlbum 26711
120Y Bakkie
Workhorse
Title: DATSUN 120Y [2 men in hardhats with yellow pickup]
1978.09 bakkie 120Y Bakkie
Format:flyer 1-sheet, 2-sides Size: Publication Number:L-0-001/78
DATSUN 120Y
The bakkie that handles like a workhorse and gets wolf-whistles. Die bakkie wat soos 'n werkesel hanteer en wolf-fluitjies kry.
29636.jpgAlbum 29636
DATSUN
GREAT FEATURES MAKE DATSUNS GREAT. GROOT KENMERKE MAAK DATSUNS GROOT.
29637.jpgAlbum 29637
28253.jpgAlbum 28253
SPECIFICATIONS
DIMENSIONS AND WEIGHTS:
Overall length 3 845 mm
Overall width 1 495 mm
Overall height 1 395 mm
Wheelbase 2 300 mm
Tread (front) 1 250 mm
Tread (rear) 1 245 mm
Minimum ground clearance 160 mm
Rear body interior length 1 565 mm
Rear body interior width 1 285 mm
Rear body interior height 410 mm
Gross vehicle mass 1 400 kg
Vehicle mass (tare) 696 kg
Seating 3 persons
PERFORMANCE:
Maximum speed 140 km/h
% gradient at full load 32,6%
Minimum turning radius 4,1 m
ENGINE:
Type: Petrol engine, 4 cycle, 4 cylinder
in-line, OHV, water-cooled. Bore and
Stroke: 73 x 70 mm.
Displacement 1 171 cm3
Compression ratio 9,0 to 1. Maximum
power 49 kW @ 6 000 r/min.
Maximum torque 93 Nm @ 3 600
r/min.
FUEL SYSTEM:
Carburettor: dual barrel, down draught
Fuel pump: mechanical type diaphragm pump.
Fuel tank capacity: 37 litres.
Fuel consumption: *6,2l per 100 km at 80 km/h.
* Car magazine figure.
LUBRICATION SYSTEM:
Lubrication method: pressure feed,
full flow.
ELECTRICAL SYSTEM:
Battery: 12 volt 45 Ah. 35A
alternator with regulator.
TRANSMISSION:
4-speed manual full synchromesh with
floor change. 1st-3,757; 2nd-2,169;
3rd-1,404; 4th-1,00; Reverse-3,640;
Final drive-4,11:1.
BRAKES:
Tandem master cylinder, dual brake
circuit; drum brakes front and rear.
Total lining area 546,0 cm2
SUSPENSION:
Front: Independent strut type with coil
springs, tension rod and stabilizer.
Rear: Live axle with semi-elliptical
leaf springs and telescopic
double-acting shock absorbers.
NOTE: These specifications are
subject to change without notice.
1. Sidemounted turning indicator repeaters.
2. 500 x 12,6 ply tyres.
3. Under-bumper side lights and turning indicators
4. 2-speed windscreen wipers and washers.
5. Twin outside rear mirrors.
6. Padded dash and non-glare instrumentation.
OTHER STANDARD FEATURES INCLUDE:-
Lockable fuel filler flap.
Rear window protection bars.
Double side & tail gate panels on load box.
Load tie down hooks.
Glove box.
Parcel tray,
High quality moulded floor carpet.
Interior lamp.
Two sunvisors/bench seat covered in long lasting vinyl
material.
OPTIONS:-
Date issued: Sept. 1978 Order No.: L-0-001/78
The choice of 2 "Dazzle Datsuns" — The "Van der Merwe"
and "Bester" — both making these the only bakkies
available, direct from your dealer with such as:-
Magnesium road wheels.
Radial ply tyres.
Sporty "Dazzle" body stripes
Black-out front bumper and fender mirrors.
Tonneau cover.
DATSUN
DATSUN NISSAN
174_6197da008c0d6.jpgPost 496223
5.00x12, 6-ply tyres with 'D' hubcaps
174_6197da0b4c869.jpgPost 496223
174_6197da167f84a.jpgPost 496223
174_6197da4f292a3.jpgPost 496223
twin outside rear mirrors
174_6197da65aa16c.jpgPost 496223
174_6197da744c789.jpgPost 496223
