<-- back to South Africa Brochures
Werkesel of Pretperd
1990 Bakkie-Kar, Nissan's 1400 1/2-tonners - It's bred to work but loves to play
IT'S BRED TO WORK BUT LOVES TO PLAY
WERKESEL OF PRETPERD
workhorse or fun horse
OUR AMAZING BAKKIE-CAR. NISSAN'S 1400 1/2-TONNERS.
ONS VERSTOMMENDE BAKKIE-KAR. NISSAN SE 1400 1/2-TONNERS.
NISSAN
120Y Bakkie
Workhorse
Title: DATSUN 120Y [2 men in hardhats with yellow pickup]
1978.09 bakkie 120Y Bakkie
Format:flyer 1-sheet, 2-sides Size: Publication Number:L-0-001/78
DATSUN 120Y
The bakkie that handles like a workhorse and gets wolf-whistles.
Die bakkie wat soos 'n werkesel hanteer en wolf-fluitjies kry.
DATSUN
GREAT FEATURES MAKE DATSUNS GREAT.
GROOT KENMERKE MAAK DATSUNS GROOT.
SPECIFICATIONS DIMENSIONS AND WEIGHTS: Overall length 3 845 mm Overall width 1 495 mm Overall height 1 395 mm Wheelbase 2 300 mm Tread (front) 1 250 mm Tread (rear) 1 245 mm Minimum ground clearance 160 mm Rear body interior length 1 565 mm Rear body interior width 1 285 mm Rear body interior height 410 mm Gross vehicle mass 1 400 kg Vehicle mass (tare) 696 kg Seating 3 persons PERFORMANCE: Maximum speed 140 km/h % gradient at full load 32,6% Minimum turning radius 4,1 m ENGINE: Type: Petrol engine, 4 cycle, 4 cylinder in-line, OHV, water-cooled. Bore and Stroke: 73 x 70 mm. Displacement 1 171 cm3 Compression ratio 9,0 to 1. Maximum power 49 kW @ 6 000 r/min. Maximum torque 93 Nm @ 3 600 r/min. FUEL SYSTEM: Carburettor: dual barrel, down draught Fuel pump: mechanical type diaphragm pump. Fuel tank capacity: 37 litres. Fuel consumption: *6,2l per 100 km at 80 km/h. * Car magazine figure. LUBRICATION SYSTEM: Lubrication method: pressure feed, full flow. ELECTRICAL SYSTEM: Battery: 12 volt 45 Ah. 35A alternator with regulator. TRANSMISSION: 4-speed manual full synchromesh with floor change. 1st-3,757; 2nd-2,169; 3rd-1,404; 4th-1,00; Reverse-3,640; Final drive-4,11:1. BRAKES: Tandem master cylinder, dual brake circuit; drum brakes front and rear. Total lining area 546,0 cm2 SUSPENSION: Front: Independent strut type with coil springs, tension rod and stabilizer. Rear: Live axle with semi-elliptical leaf springs and telescopic double-acting shock absorbers. NOTE: These specifications are subject to change without notice. --------------- 1. Sidemounted turning indicator repeaters. 2. 500 x 12,6 ply tyres. 3. Under-bumper side lights and turning indicators 4. 2-speed windscreen wipers and washers. 5. Twin outside rear mirrors. 6. Padded dash and non-glare instrumentation. --------------- OTHER STANDARD FEATURES INCLUDE:- Lockable fuel filler flap. Rear window protection bars. Double side & tail gate panels on load box. Load tie down hooks. Glove box. Parcel tray, High quality moulded floor carpet. Interior lamp. Two sunvisors/bench seat covered in long lasting vinyl material. OPTIONS:- Date issued: Sept. 1978 Order No.: L-0-001/78 The choice of 2 "Dazzle Datsuns" — The "Van der Merwe" and "Bester" — both making these the only bakkies available, direct from your dealer with such as:- Magnesium road wheels. Radial ply tyres. Sporty "Dazzle" body stripes Black-out front bumper and fender mirrors. Tonneau cover. DATSUN GREAT FEATURES MAKE DATSUNS GREAT. DATSUN NISSAN
5.00x12, 6-ply tyres with 'D' hubcaps
