Timing Chain
Revision as of 04:47, 14 February 2012; view current revision
Categories: Engine Mechanical | Valvetrain
The Timing Chain drives the Camshaft.
Also see: Timing Cover
  • We have seen a couple of single link timing chains on A12, which is probably the original A10 single row chain. Insist on the factory specified double-chain, like Nissan did for later A10s.
  • A rattle can be the trait of a stretched timing chain. Pinging/pinking has also often been mistaken for timing chain rattle
A-series engine has a short timing chain -- and with an automatic adjuster -- it rarely stretches or goes bad.
Compare to the loooooong chaing used in the Nissan KA24E engine:
  • KA24 often has timing chain problems
Replacement
Alignment
Check the cam gear alignment. It should be exactly like this:
If it is not, see Camshaft#Timing.
3639.jpg http://datsun1200.com/modules/myalbum/photos/thumbs/3640jpg
The timing chain kit (timing set) includes: Cam, Crank, Chain, Tensioner
Cam Sprocket
(38 teeth)
Chain
  • 0240226-1.jpg $17.99, Partsamerica.com
Tensioner
Crank Sprocket
19 teeth
B110 RAW LIST
13024-H8500 SPROCKET-CAMSHAFT
13024-18001 SPROCKET-CAMSHAFT
13082-18000 BOLT-CAMSHAFT SPROCKET
13030-18000 WASHER-CAMSHAFT
08915-2401A WASHER-LOCK
08915-14010 WASHER-LOCK
13028-18001 CHAIN-CAMSHAFT
13070-18001 ASSY-TENSIONER CHAIN
08120-63510 BOLT-FIXING CHAIN TENSIONER
08915-13610 WASHER-LOCK FIXING CHAIN TENSIONER
Adjustable Cam Gear
Fitting an adjustable Camshaft gear lets you fine tune the timing. The cam vendor's recommendations are usually best, but retarding the cam a degree or two will generall shift the torque curve higher up in the RPM range. Advancing the cam will (usually) lower the power curve a few RPM. Adjustable gears come in a few basic kinds:
  • Multi-key. Rollmaster had one with nine adjustible keys in the crank sprocket
  • Multi-hole. Using different holes
  • Variable: Slotted holes allow a continuously variable range
7339.jpg Rollermaster
