Z-series Engine Swap
Revision as of 03:32, 4 February 2013; view current revision
Categories: Engine Modifications | Engine Swaps
The Nissan Z Engine is readily available in both USA and Australia in early 1980s Datsuns and Nissans. They came in displacments of 1.8 (Z18), 2.0 (Z20) and 2.2 (Z22) liters. The Z-series and L-series Engine are very closely related, it is possible to put a Z head on a L-series bottom end with the use of the Z24 front cover. Z18s are a top little motor and readily available in Australia. If price is no object, the CA18DET is a lighter and far more powerful engine. However, if you come across a Z18T and the price is right, it makes a little Datsun 1200 move out with style.
See main article: Nissan Z Engine
Z-series is the 2nd generation of the L-series engine. So oil pans and mounting is the same as fitting an L-series engine.
Also see L-series Engine Swap crossmember, sump sections.
Z18ET setup http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=37690
3879.jpg 7098.jpg 10490.jpg 13171.jpg 13561.jpg 13562.jpg 17760.jpg 20889.jpg 22405.jpg 22406.jpg
Sources
AUS Bluebird Series I Z18ET
Transmission
Z-series uses the same transmissions as the KA-series engines. The bolt pattern is the same as the L-series but the lean is different.
See Transmission section of KA Engine Swap
Crossmember & Sump
Z-series Engine uses same crossmember mounts points as L-series engine.
See L/Z/KA/SR Crossmember
Oil Pan
720 4x4 pan modified to fit stock 1200 crossmember
But why go to all that trouble?
Vanette Z-22 sump fits stock crossmember:
