Also see:
Dashboard
1972 Facelift
See more details of all the 1972 redesign for the Japan market: Facelift.
Ute Dash
Gauges
Tachometer
See Tachometer
Clock
See Clock
Fuel Gauge
1972 USA Owners manual
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
Also see: Fuel tank
Indicator/Warning Lights
- Ignition Warning Light
- Oil Pressure Warning Light
- Headlight Beam Indicator Light
- Brake System Warning Light
- Turn Signal Indicator Lights
Also see: Wiring
Also see: Thermostat
Water Temperature Gauge
Glovebox
Hot tip: replace the cardboard box with a plastic unit from an early B210.
Hinge detail. If often wears away the box material. The B210 unit will fix this.
