620 Parts Donor
Revision as of 07:15, 21 April 2014; view current revision
Category: Parts Donors
Datsun 620 Truck shares some parts with Datsun 1200
Japan Market production 1972-SEP 1979
  • 620 J13 engine
  • N620 J15 engine
  • R620 SD22 engine 7809-
Used R4W63 transmission (column shift)
N = J15 Engine
USA (japan-built)
  • 1973 Model year L16 engine
  • 1974 L18 engine
  • 1975-1979 L20B engine
Applied Model
Any Nissan Part Numbers for 1200 that have this applied model code xxxxx-NNNxx are likely to be found in a 620 truck, where NNN is:
  • B50: Datsun 620 RHD
  • B93: Datsun 620 Truck RHD 7510-
  • B94: Datsun 620 Truck RHD 7605- Custom [extended cab]
  • B95: Datsun 620 Truck RHD
  • B96: Datsun UN620 Pickup (coupe utility)
  • B64: Datsun 620 pickup LHD
  • G70:
  • G71: Datsun 620 Truck RHD 7809-
Desirable Parts
  • 1979 Wiper Switch for Intermittent Wipers
  • 1979 Wiper AMP
  • 1974-1979 Wiper Switch (lighted type) can be adapted same as the intermittent type
  • Black interior Door escutcheons (will replace 1200 chrome ones)
  • Fuse Box
  • 1979 35A Alternator with Internal Regulator (bolt in upgrade for B110)
  • Bucket seats -- thin B210 style, fits 1200 utes nicely
Engine
  • 12308-H1000 WASHER-PULLEY CRANKSHAFT J15 ENGINE 7602-
  • 13231-H1001 LIFTER-VALVE J15
  • 14006-18000 [B10] PIN [for J15? intake manifold]
  • 14026-18001 WEIGHT-COUNTER HEATER CONTROL J15 [exhaust manifold heat riser]
  • 14022-18000 SPRING-HEATER CONTROL J15
  • 15208-H1010 ELEMENT-OIL FILTER J15
  • 21200-H7802 THERMOSTAT 76.5C
  • 21480-18000 COCK-WATER DRAIN RADIATOR J15 -7612
  • 21481-18000 PACKING-DRAIN RADIATOR J15 -7612
  • 21482-18000 SEAT-DRAIN RADIATOR J15 -7612
  • 18221-H5005 [B210] BRACKET-WIRE ACCELERATOR J15 -7708 [throttle cable bracket]
  • 18415-H1001 KNOB-CHOKE CONTROL
Fuel
  • 17103-H7260 [B210 A14] CONNECTOR ASSY-FUEL INLET J15 [right angle fuel pump inlet]
  • 17103-H5310 [B210] CONNECTOR ASSY-FUEL OUTLET J15 [right angle fuel pump OUTLET]
  • 16331-H1000 COMPENSATOR-IDLE [air cleaner compensator valve]
  • 16335-H5700 ORIFICE-A AIR CLEANER TUBE
  • 16547-H1000 PACKING [air cleaner-to-air filter gasket (2 needed)]
  • 16546-18000 ELEMENT ASSY [air filter]
  • 16548-18000 PACKING [air cleaner lid-to-base gasket]
  • 16568-H1000 PACKING [air cleaner nut gasket]
  • 17515-H5501 HOSE-BREATHER -7801 L=360 [tank to reservoir]
  • 17515-H5510 HOSE-BREATHER -7801 L=625 [tank to reservoir]
  • 17515-H5506 HOSE-BREATHER -7801 [filler tube to reservoir]
  • 17515-H5502 HOSE-BREATHER -7801 L=300 [tank to reservoir]
  • 17342-18000 RING-O FUEL GAUGE
Power Train
  • 30610-H5802 [B210] CYLINDER ASSY-CLUTCH MASTER 5/8 7603-
  • 30631-H5801 [B210] ROD ASSY-PUSH 7603-
  • 41128-18000 SCREW-BLEEDER TOKICO [clutch slave]
  • 46206-18000 SPRING-LOCK [clutch slave line bracket clip]
  • 63-series 4-speed parts (bearings, perhaps synchros)
620 Pickup (Ute)
* 17310-H1000 PLUG-DRAIN [fuel tank]
* 17312-H1000 PACKING-DRAIN PLUG [fuel tank]
Brakes
  • 36437-18000 NUT-ADJUSTING [rear left emergency brake line, at center pivot]
  • 41158-18000 PACKING-CONNECTOR FRONT BRAKE -7708 [for front brack hose ay cylinder]
  • 44112-H3300 CUP-PISTON REAR BRAKE 11/16 NABCO 7709-
  • 44112-H3310 CUP-PISTON REAR BRAKE 11/16 TOKICO 7709-
  • 44158-18000 PACKING [brake line to cylinder]
  • 46512-H0101 STOPPER-RUBBER [brake pedal]
  • 46510-18000 STOPPER-PEDAL [brake pedal]
  • 46525-18000 BUSH-PEDAL -7904
  • 46206-18000 SPRING-LOCK BRAKE HOSE -7708
  • 46234-H1100 CONNECTOR-BRAKE TUBE
  • 46313-18000 CONNECTOR-BRAKE TUBE -7708
Chassis
  • 40038-H1000 BOLT-STOPPER [knuckle arm stop]
  • 43067-H0100 STUD -7805 [axle housing to carrier studs]
  • Steering wheel looks similar
  • 54472-18000 WASHER-THRUST TENSION ROD 7709-
  • 54481-18000 BUSHING MOUNTING TENSION ROD 7709-
  • 54630-H1001 COLLAR-TENSION ROD 7709-
Electrical
  • Cluster looks same
  • Wiper system & linkage looks same
  • Fuse Box
  • 22136-H2300 PLATE ASSY-BREAKER HITACHI J15
  • 22157-H1000 ROTOR-HEAD HITACHI J15
  • 22157-18010 ROTOR-HEAD MITSUBISHI J15
  • 22403-18005 TERMINAL ASSY HITACHI J15
  • 22750-H2300 SCREW KIT HITACHI J15 [distributor]
  • [B210] Alternator LT135 Hitachi
  • [B210] Alternator LT150 Hitachi
  • [B210] Alternator Mitsubishi
  • 25442-H2500 LINK-FUSIBLE
  • Gauge Cluster looks similar
  • Tachometer same, but direct wired
  • Speedometer looks same
  • 26260-H1800 SOCKET ASSY-BULB F/TURNSIGNAL
  • 24815-H3121 RELAY-BUZZER
  • 25165-H1000 KNOB-LIGHTING SWITCH
  • 25230-H1604 RELAY ASSY-WATER TEMPERATURE F/WATER TEMP -7603
  • 25230-H6203 [B210] RELAY ASSY-EGR CUT -7708
  • 25265-H1000 KNOB-WIPER SWITCH
  • 25320-H1000 SWITCH ASSY-STOP LAMP
  • 27450-H6200 [B210] BRACKET ASSY-TANK 7708- [radiator overflow]
  • 27480-H1001 TANK ASSY-WINDSHIELD WASHER
  • Radio
  • Speakers
  • 27962-H1100 ANTENNA -7612
  • B9200-H1000 STEREO KIT-CARTRIDGE [8-track tape]
  • Clock look similar
  • 27640-H1001 TANKS ASSY-LIQUID DKKC [air con]
  • Air con, some parts fit B210
  • 22137-H1000 KNOB-CONTROL LOWER NICHIRA [heater]
  • 22138-H1000 KNOB-CONTROL UPPER NICHIRA [heater]
Pickup (uses VB110 wagon rear lights)
* 26551-H1401 LENS-COMBINATION LAMP RH
* 26556-H1401 LENS-COMBINATION LAMP LH
* 26550-H1401 LAMP ASSY-REAR COMBINATION RH
* 26555-H1401 LAMP ASSY-REAR COMBINATION LH
* 26553-H1400 PACKING LAMP-RH
* 26558-H1400 PACKING LAMP-LH
* 26515-H1000 LAMP ASSY-LICENSE RH
Body
  • Hood/Bonnet latch
  • 65510-H1000 ROD-HOOD SUPPORT [prop rod]
  • 66512-H2500 GROMMET-HOOD SUPPORT ROD
  • 65514-H1000 CLAMP-HOOD ROD [rod clip]
  • 76486-H1000 Body Sill Retainer [rocker panel trim clip]
  • 64803-18000 Canoe Rivet for B10 [holds 620 front wheel well inner splash cover]
  • 66919-H1001 CLIP -7708 [for kick panel]
  • 73940-H1101 ASSIST STRAP-FRONT [above door]
  • 76911-H1101 GARNISH-WINDSHIELD PILLAR RH GRAY -7708
  • 76912-H1101 GARNISH-WINDSHIELD PILLAR LH GRAY -7708
  • 80940-H1101 ARMREST-FRONT DOOR RH BLACK
  • 80940-H1100 620 (BLACK) OPTION to 0678, standard equipment from 0778 USA
  • 80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA
  • 80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
  • 80504-H1001 REMOTE CONTROL ASSY-DOOR LOCK RH [inside lever & internal rod]
  • 80505-H1001 REMOTE CONTROL ASSY-DOOR LOCK LH [inside lever & internal rod]
  • 90609-H1400 NUT-OUTSIDE HANDLE ROD [door handle]
  • 84371-H1000 HOLDER-OUTSIDE HANDLE
  • 80508-H1000 SPRING-RETAINING RH
  • 80509-H1000 SPRING-RETAINING LH
  • 80690-E6000 CASE ASSY-KEY
  • 80600-H1001 CYLINDER ASSY-DOOR LOCK RH
  • 80601-H1001 CYLINDER ASSY-DOOR LOCK LH
  • 76960-H7400 [B310?] CYLINDER ASSY-GAS FILLER LOCK
  • 96315-H1000 BASE-MIRROR OUTSIDE [wing mirror]
  • 96327-H6200 [B210] BASE-MIRROR INSIDE
  • Inside Mirror (part number differs, but base is the same, so it will bolt on)
  • 63845-18000 [B10] CLIP-TUBULAR -7708 [clip for push-in badges]
620 Pickup (Ute)
* 85012-H1000 Rear Bumper RH end
* 85013-H1000 Rear Bumper LH end
* 85206-H1401 rear bumper bracket RH
* 76844-H1201 LOCK ASSY-SIDE WINDOW RH
* 76832-H1201 HINGE-SIDE WINDOW
* 76828-H1200 COVER-SIDE WINDOW HINGE
* 76846-H1201 WASHER [window glass]
* 96905-27800 LABEL-LOADING CAPACITY 400KG (later used on B310 Van)
