63-Series Transmission
Revision as of 03:28, 17 July 2007; view current revision
Category: Transmission
The 63a transmission is a large strong transmission. It was adapted by Nissan to fill a marketing need in USA for a 5-speed (to compete with the Corolla SR-5) and so the existing 63a was modified to fit the small A-series engine. This has two special significances:
  • It is strong, suitable for overbored, supercharged or turbocharged A-series engines
  • Its successor, the 60-Series Transmission 5-speed is much lighter and so a better fit for A14 and A15 naturally aspirated engines. The 60 is also smaller than 63 and so a better fit in Datsun 1200s.
The 63A came in two versions:
  • 63A to fit L-series engine
  • 63A to fit A-series engine
So check the bellhousing bolt pattern.
Datsun boxes are numbered by the distance between the centres of the countershaft and the main shaft. The 63-series has 63 mm between the shaft centres.
The "A" indicates the transmission revision, not the engine type it fits. ? my casting has a 63A#1 cast were there different versions?
  • 63A
Dogleg 5 speed overdrive 5th Slave cylinder is on the left side Uses AT prop shaft What clutch? What was the special vehicle these came out of?
  • 63L
63-Series 5-speed Swap Notes
63a crossmember
Note that the factory crossmember mounting brackets have been removed from inside the tunnel. This crossmember bolts to the floor.
Get a Datsun 810 speedometer cable, it's about 150 mm longer.
You'll need a prop shaft from an AT equipped 60 series tranny as it uses the same output shaft.
63a
Gear Ratios
</td></tr>
GearF5C56A GX5F5C56A Opt. 1F5C56A Opt.2Overdrive 5Overdrive 5FS5W60A A14FS5W60A A15FS5W63A A14
1st3.7573.7572.6763.5133.5133.5133.5133.382
2nd2.3742.3741.6912.172.172.172.172.013
3rd1.6591.6591.3981.3781.3781.3781.321.312
4th1.2541.2911.18111111
5th1110.8750.8250.8210.8210.854
Rev4.044.042.8773.7643.7643.7643.7643.57
NoteStock B110 & B210 GX-5wide ratio PN 32010-H7251Pclose ratio PN 32010-H7220N??1980 NA shop manual1980 NA Shop manual1978 NA Shop manual
Also see: 4-speed gear ratios at end of article 5-Speeds
Category:Drivetrain Modifications
