Datsun 1200s were fitted with various consoles including full-style and compact style.
Full Size
Full size console was usually fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tach in the console if you so choose.
SSS
GX
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog * 74980-H2010 ASS'Y-CONSOLE BOX [full, fitted to GL manual models] * 74980-H2020 ASS'Y-CONSOLE BOX [full, fitted to GL automatic models]
Japan catalog * 74980-H2010 ASS'Y-CONSOLE BOX [full, fitted to GL manual models] * 79482-H1801 FINISHER-console box * 74980-H2020 ASS'Y-CONSOLE BOX [full, fitted to GL automatic models] * 27389-H2300 SPACER-rubber (fixing clock to console box) (op.) ALL
1972 Japan [Facelift] catalog * 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL 4-speed * 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog * 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772 * 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772- * 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
'Sunny' 25005-H1800 MASK-tachometer [instrument panel] 74990-H2021 MASK-clock [console] 85-13412-1 SCREW 3 89-15434-1 WASHER-plain 3
'Datsun' 25005-H1810 MASK-TACHOMETER "DATSUN" [instrument panel] 74990-H1800 MASK-CLOCK [console] 08513-41212 SCREW 3 08915-43410 WASHER-PLAIN 3
Short Console
The short pocket-type console was fitted to:
- USA Automatic 1200s
- OPTION 4-speed 1200s STD and DX
- JAPAN 3-speed column shift OPTION
- B120 Pickups as standard equipment (except STD models)
Console Boot for shift lever (aftermarket)
シフト ブーツ
Full and short consoles use the same shifter boot.
- G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
1971-4/12 Japan catalogs
- 74980-H1801 ASS'Y-CONSOLE BOX, with bracket 4-speed (ex. GL, GX)
- 74982-H1801 FINISHER-console box
- 74986-H1801 ASS'T-BOOT
- 74980-H1021 ASS'Y-CONSOLE BOX, with bracket A-all (ex. GL)
North America catalog
- 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC
- 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC
B120 1974 Catalog
- 74980-H1801 BOX ASS'Y-console, with bracket [Black]
- 74982-H1801 FINISHER-console box [chrome trim]
- 74986-H1801 BOOT ASS'Y
- 08510-61642 SCREW (8)
- 08915-43642 WASHER-plain (4)
- 01241-00061 NUT-spring (4)
B120 1997 Catalog
- 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET 7510-7803 [Black]
- 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
- 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
- 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910
- 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
- 74982-H1801 PANEL-CONSOLE A 7510-8109 [trim]
- 74982-G1900 PANEL-CONSOLE A 8110-8910 [Chrome trim] K504
- 96930-95W00 PANEL-CONSOLE A 8910- [gray trim]
- 74986-H1801 BOOT-CONSOLE 7510-8109
- 74986-G1160 BOOT-CONSOLE 7804-7907 DARK BROWN
- 74986-G1660 BOOT-CONSOLE 7908-8910 BROWN
- 96935-95W00 BOOT-CONSOLE 8910- GRAY
- 74987-H1801 BRACKET-CONSOLE FRONT
- 08510-61642 SCREW (2)
- 08961-13240 NUT (2)
- 01241-00061 NUT (2)
- 08510-61697 SCREW (2)
- 74988-G1160 BRACKET-CONSOLE REAR
Fibreglas
Aftermarket
Amco aftermarket/dealer installed
Custom
Portugal 1200s. Are the custom consoles?
Documentation
Alternative Sources
Excellent
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also these unique 3-gauge versions. For more, see: PB110
PB110s could also come with regular-style gauge layout
B210 Console
Does not fit the 1200 well
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD 96935-H9160 BOOT (BLUE) 0879- $32.62 USD 96935-H9100 BOOT (BLUE) -0779 $30.12 USD 96935-H8561 BOOT (BROWN) $35.58 USD
click
keywords: コンソール
