FJ engine swap
Revision as of 08:49, 16 April 2016; view current revision
Categories: Engine Modifications | Engine Swaps | Nissan Engines
The F20DET engine was basically a detuned race engine, a bit heavy but possibly Nissan's strongest ever engine. The stock engine can take massive boost and survive, while turning out incredible horsepower. Originally designed as the FJ24 for use in 240RS racing cars, it was in mass production as the FJ20 engine fitted to the DR30 Nissan Skyline. The FJ engine is very heavy at 366 lbs, heavier than the 318 lb Buick V8 3.5 liter engine. The FJ engine was produced in three variations: 1) FJ24E 2) FJ20E 3) FJ20ET.
For general information, see: http://fj20.com
The mighty FJ20E makes 148 HP from 2-liters, and with a turbo the FJ20ET makes up to 203 HP in stock form.
PRO12T
FJ20ET Turbo
wikipedia
Although it is heavier than a GM 3800 V6, the FJ fits somewhat better into a 1200's engine bay. It looks most excellent, doesn't it?
Sources
FJ Engine Source:
  • 1982-1983 Nissan Silvia BS110 '240RS' 240 HP, Works 275 HP
  • 1983-1988 Nissan Silvia S12 FJ20E 150 PS, FJ20ET 190 PS, FJ20ET inter-cooled 205 PS
  • 1982-1985 Nissan Skyline DR30 '2000RS' FJ20E 110kw
  • 1983-1984 Nissan Skyline DR30 '2000RS Turbo' or 'RS-X Turbo' FJ20ET 140kw
  • 1984-1985 Nissan Skyline DR30 'RS-X Turbo C' FJ20E 151 kw
Which is better? FJ20 or SR20?
Both:
  • make about the same HP in stock form (SR20DE 140-169HP, F20E 150 HP)
  • In turbo versions, both are too large for as 1200 (too large for normal engineering process) in most Australian states. In these States, the CA18DET is better than SR20DET or FJ20ET for street cars.
FJ20DET
  • In stock condition, can take more boost than SR20DET, thus more HP without opening the engine up
SR20
  • Much lighter, so won't be as detrimental to handling
  • More were produced, so prices are lower
Build-Ups
  • FJ20 has all the usual build-up parts, same as SR20. However as less FJs were produced, so too the market for FJ parts is more expensive than SR parts.
FJ-powered 1200s
TIG20T
SuPeR's ute
YAQ70Z
Sandy's fj1200
album 22628.jpg 22629.jpg 22630.jpg 22626.jpg 18032.jpg 17521.jpg 17520.jpg 17519.jpg 17518.jpg 17426.jpg 17243.jpg 17242.jpg 17241.jpg 17240.jpg 17239.jpg 13921.jpg 13911.jpg 10750.jpg 10749.jpg 10748.jpg 10747.jpg 10746.jpg 10745.jpg 10744.jpg
Monterey Park
Paul Stanek's IPC Turbo Charging B110 Coupe
34 PSI
TUF120
Joshh
Main:Joshh's FJ20et 1200 ute
FJ2020 on Simmons FR
FJ2020 on Convo rims
FJ-powered B210
See this article, about a FJ-powered B210:
510 Swaps
11120_49e67a0ff2d8a.jpg 11120_49e67a195c1f0.jpg 11120_49e67a2307c39.jpg 11120_49e67a2bc1a65.jpg 11120_49e67a344a000.jpg 11120_49e67a8cd5acd.jpg 11120_49e67a9a45c60.jpg 11120_49e67b447298f.jpg 11120_49e67f66cde6a.jpg 11120_49e67f87add4d.jpg
Swap Notes
Distributor
The FJ distributor uses Nissan Optical CAS for EFI computer signaling. See FJ CAS.
If converting to carbureted, use a standard distributor. The distributor from a Datsun A12 engine fits into the FJ20 engine block, but you need to change drive gear from A12 to FJ20 drive gear.
If the distributor is missing, use an A12 Datsun or Austin mini distributor. An A12 electronic ignition distributor is preferred so you can use the output to an aftermarket ECU.
22100 DISTRIBUTOR ASSY
R30 (8108-9003) FJ20E & FJ20T
22100-R2000 8110-8206 ハーネス L=410 MM [FJ20E only]
22100-R2007 8206-8308 ハーネス L=580 MM マイナー マ デ
22100-R2001 8308-8601 Hitachi マイナ ゴ センヨウ
22100-R2002 8601-8612 Hitachi
22100-R2003 8612-9003 Hitachi
22100-R2007 DR7 type
FJ20 timing plate
578.jpg 579.jpg 580.jpg 1082.jpeg 1168.jpg 1197.jpg 1198.jpg 1199.jpg 1210.jpg 1342.jpg 1343.jpg 1344.jpg 2044.jpg 2045.jpg 2046.jpg 2047.jpg 2048.jpg 2234.jpg 2509.jpg 2510.jpg 2514.jpg 2699.jpg 2910.jpg 2911.jpg 2932.jpg 2987.jpg 3108.jpg 3109.jpg 3277.jpg 3322.jpg 3448.jpg 3497.jpg 3498.jpg 3932.jpg 3933.jpg 4114.jpg 4117.jpg 4186.jpg 4187.jpg 4188.jpg 4189.jpg 4678.jpg 4895.jpg 5326.jpg 5328.jpg 5471.jpg 5976.jpg 5981.jpg 6577.jpg 6779.jpg 6915.jpg 7550.jpg 8154.jpg 8155.jpg 8156.jpg 8157.jpg 8158.jpg 8159.jpg 9398.jpg 9449.jpg 9464.jpg 9937.jpg 9938.jpg 9939.jpg 9940.jpg 9941.jpg 10744.jpg 10746.jpg 10747.jpg 10748.jpg 10749.jpg 10750.jpg 12537.jpg 12538.jpg 13081.jpg 13082.jpg 13083.jpg 13084.jpg 13243.jpg 13244.jpg 14628.jpg 14629.jpg 14630.jpg 14937.jpg 14938.jpg 15108.jpg 15109.jpg 16136.jpg 17207.jpg 17208.jpg 17649.jpg 17944.jpg 18332.jpg 21542.jpg 22626.jpg 22627.jpg 22628.jpg 22629.jpg 22630.jpg 22888.jpg 22889.jpg 22890.jpg 22891.jpg 22901.jpg 22902.jpg 23041.jpg
