Sedan badges
Revision as of 15:24, 25 February 2017; view current revision
Category: Body
<- Back to Badges
16673.jpgAlbum 16673 16134.jpgAlbum 16134 17765.jpgAlbum 17765 9928.jpgAlbum 9928 758.jpgAlbum 758 20863.jpgAlbum 20863 20862.jpgAlbum 20862
South Africa GX badges
10248.jpgAlbum 10248
Grille
20869.jpgAlbum 20869
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
11318.jpgAlbum 11318
#1972 Center Ornament
22828.jpgAlbum 22828
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
24321.jpgAlbum 24321 11318.jpgAlbum 11318
19527.jpgAlbum 19527 21120.jpgAlbum 21120 737.jpgAlbum 737 24563.jpgAlbum 24563
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpgAlbum 752 22828.jpgAlbum 22828 7522.jpgAlbum 7522 13057.jpgAlbum 13057 bfsjq597-img600x450-1293012459v70sxm12525.jpg S_badge_reverse.jpg bfsjq597-img600x450-1293012459yvrlgd12525.jpg bfsjq597-img600x450-1293012459er55u512525.jpg
457.jpgAlbum 457
retrofitted to early grille
23190.jpgAlbum 23190
Grille Left Side Badge
DX early - no trim badge on grille
DX 1972 #62330-H3125 EMBLEM SET-radiator grille "DELUXE"
GL early #62330-H2026
GL 1972 #62330-H3325 EMBLEM SET-radiator grille "GL"
GX early #62330-H2325 COUPE, SEDAN
GX 1972 #62330-H3425 EMBLEM SET-radiator grille "GX"
1972 GX5 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
62330-H2325
GX early COUPE, SEDAN grille badge has long studs for mounting through the grille
62330-H2325.jpg 62330-H2325_.jpg th_GX-grille-badge-2.jpg th_GX-grille-badge-1.jpg th_yunakiti-img600x450-1277628693ok47g777311.jpg th_yunakiti-img600x450-1277628693ybadxo77311.jpg th_yunakiti-img600x450-1277628693qqw7ym77311.jpg th_62330-H2225.jpg th_62330-H2225_reverse.jpg 18053.jpgAlbum 18053
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
62330-H2026
screw-on type. Rear GL badge is push-in type.
gl-GRILLE-badge.jpg 20864.jpgAlbum 20864
62330-H3125
EMBLEM SET-radiator grille "DELUXE" [1972]
7522.jpgAlbum 7522 25974.jpgAlbum 25974
compare to rear badge 84823-H1000
22513.jpgAlbum 22513
62330-H3325
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" has long studs for mounting through the grille
compare to early rectangular GL badge #62330-H2026
Cast mark "62330-H3300"
62330-H3425
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX"
25658.jpgAlbum 25658
16719.jpgAlbum 16719
Side
20868.jpgAlbum 20868
Rear Quarter
76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
20867.jpgAlbum 20867
Location
14093.jpgAlbum 14093 14094.jpgAlbum 14094
76854-H1600
10578.jpgAlbum 10578 20843.jpgAlbum 20843
24320.jpgAlbum 24320 24323.jpgAlbum 24323
C-pillar
C-pillar Emblems: DX, GL, GX
20866.jpgAlbum 20866
DX: 80mm wide? , GX: 99mm wide?, GL 109mm wide?
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
20848.jpgAlbum 20848
#76852-H2001 BADGE-"GL" SEDAN-GL
23133.jpgAlbum 23133
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
5204.jpgAlbum 5204
C-pillar Badge Location
1977 GX
15399.jpgAlbum 15399
1973 DX
6576.jpgAlbum click to view
1970? press photos
751.jpgAlbum 751 5271.jpgAlbum 5271
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places:
* 1970-1971 - down low
* l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
748.jpgAlbum 748
1971 - below the corner
1973 at the corner
76852-H1000
13484.jpgAlbum 13484 20848.jpgAlbum 20848 24325.jpgAlbum 24325 24324.jpgAlbum 24324
76852-H2001
23133.jpgAlbum 23133 CGL.jpg CGL_.jpg GL-c_pillar_badge_reverse.jpg m73760119scoresnewyork-img600x450-1264925423zpizbt91579.jpg m73760119scoresnewyork-img600x450-1264925429gqm2ek91663.jpg
76852-H2300
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
5204.jpgAlbum 5204 15399.jpgAlbum 15399 18264.jpgAlbum 18264 gxg1.jpg gxg2.jpg
Rear
20870.jpgAlbum 20870 14189.jpgAlbum 14189 750.jpgAlbum 750 25995.jpgAlbum 25995
Model
20894.jpgAlbum 20894
Sunny 1200 - Right Rear
23991.jpgAlbum 23991
Datsun 1200 - Right Rear
21715.jpgAlbum 21715 15650.jpgAlbum 15650 16745.jpgAlbum 16745 19425.jpgAlbum 19425 24319.jpgAlbum 24319 12129.jpgAlbum 12129 th_datsun_1200_emblem_1_73.jpg
Left Rear Sunny - UK???
Trim
Left Rear
21439.jpgAlbum 21439 17111.jpgAlbum 17111 16172.jpgAlbum 16172 2305.jpgAlbum 2305 14817.jpgAlbum 14817
Left Rear Deluxe - 84823-H1000
differs from similar looking front facelift badge
th_Deluxe_trunk_badge_B110.jpg 22513.jpgAlbum 22513 26079.jpgAlbum 26079
Left Rear GL - 84823-H2001 early
25776.jpgAlbum 25776 25777.jpgAlbum 25777 25660.jpgAlbum 25660
Left Rear GL - 1972 - 84823-H3300
non-1200 GL
Left Rear GX 84823-H2300
"see-through" script (compare to front GX badges which have a background attached)
25662.jpgAlbum 25662 9930.jpgAlbum 9930 23911.jpgAlbum 23911 23912.jpgAlbum 23912 23913.jpgAlbum 23913 23914.jpgAlbum 23914 th_gx_emblem.jpg th_gx_emblem_front.jpg th_gx_emblem_reverse.jpg th_DSC07983.jpg
GX 5-Speed 84823-H7200
25659.jpg]
Sports
4-speed Center Rear (left of license plate)
Sports badge
"Sports" 4-speed - to right of license plate
25977.jpgAlbum 25977 755.jpgAlbum 755 1972 GL Sedan rear
Automatic
Early "Full Automatic" 79200-H1020
9784.jpgAlbum click to view
Late "Full Matic" 79200-H2820 from '71 April (also used by coupe), 79200-H3200 1972
26202.jpgAlbum 26202
non-1200 'Nissan Matic' is blue 84821-U0300
N22 Coupe badge on sedan ('Nissan Automatic')
H28
19301.jpgAlbum 19301 NFA2.jpg NFA1.jpg NFA3.jpg fullmatic.jpgAlbum click to view
'GX' Badges
NOTE: there are 3 types of plain GX letter badges.
* top: early GX grille
* middle: 1972 GX grille
* bottom: GX rear (see through script)
GX grill badge vs GX rear badge (grille badge has a background):
18023.jpgAlbum 18023
#narrow 1972 grille badge
#early wide grille badge | rear see-through badge
