Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grille changed for 1972.
#Stainless Grille: Sedan, Wagon & 1971-1978 ute
#Facelift Grille (1972 JDM Sedan & South Africa sedans)
#Coupe Grille (black headlight surrounds)
#1978-1989 Ute Grille (silver headlight surrounds)
#Late Sunny Truck/Bakkie Grille (1989-2007)
Stainless Grille
Sedan grille "D" and "S" emblems
Facelift Grille
Late JDM grille + intricate "S" grille emblem
Plastic Grilles
1. Silver headlamp surrounds (#mid-model ute) 2. Black headlamp surrounds (#coupe GX) 3. With Silver center strip (#coupe non-GX)
Black headlight surrounds: (#coupe)![]()
Silver headlight surrounds: Mid #Pickup (1978-1989)![]()
Emblems: Rectangular for pickup, Round for coupe
Coupe Grille
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck/ute/bakkie used the stainless Sedan Grille.
Mid-Model Truck
1978-up Truck/ute/bakkie. This grille looks nearly identical to the Coupe grille:
- Silver headlight surrounds (coupe has black surrounds)
- Rectangular center emblem (Coupe is round)
- Emblem screws have horizontal arrangement (Coupe is diagonal)
Coupe or Ute grille accepts both emblems
Coupe emblem - screws arranged diagonally
Pickup emblem - screws arranged (nearly) horizontally
To fit a Plastic grille to an early ute or sedan, add these tabs:
Square Headlight Truck
From October 1989 * JDM Sunny Truck (late B122) * South Africa bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Coupe
Coupe continued to use the original grille during the 1972 facelift.
Sedan
See Main Article: Sedan Grille, Facelift
Customized Grilles
Blackout center ornament
JDM look
Coupe-grille with custom insert
Flush
Datrotor: Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
![D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/wiki/D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg)
![D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/wiki/D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpg)
![3bcf07cd.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/wiki/3bcf07cd.jpg)
Blackout Grille
Coupe/Ute grille painted black
Square Eye Retrofit
rectangular headlights - dual or quad
Billet
GDM Style
VW Caddy look (see post for more pics)
Bimmer E30 datsunb120
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
See: * Sedan Grille Mounting* Coupe Grille Mounting
* Coupe Grille in Sedan: add the missing brackets. * Sedan Grille in late Sunny Truck * Coupe Grille in late Sunny Truck
For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Dimensions
Coupe/Mid-ute/Late-ute * 123 x 22 x 10 cm box
Sedan/Early-ute TBD
PB110
PB110 Sunny Excellent Grille
PB110 Custom
PB110 sedan retrofitted with chromed B110 Coupe grille. The chrome matches nicely with the PB110 corner lights
keywords: グリル
